Trouble making and recieving calls on SIP
Re: Trouble making and recieving calls on SIP
I have made the compression without and still facing problem.
(1)xa000000> compvisu sys────────────────────────────────────────────────┘
Thu Oct 23 19:26:21 EST 2008
C O M P V I S U |
| Inter-node protocol H323....... yes |
| RTP Direct..................... yes |
| RTP Direct for H323 terminals.. no |
| Fast Start..................... yes |
| VAD (Voice Activity Detection): |
| - G723/G729...... yes |
| - G711........... no |
| ECE (Echo Canceller)........... yes |
| - LIO/LIOE........ 16 ms |
| - INTIP/GA/GD..... 128 ms |
| PFE (Post Filter).............. yes |
| Volume ........................ 8 |
| Volume for IP Phone ........... 0dB |
| Volume for other device. ...... 0dB |
| VRE ........................... no |
| Law (Except Media Gateway)..... A law |
| Global compression type ....... G723 |
| Multi-algorithm (for H323) .... no |
| Compression for INTIP/GD ..... without |
| Compression for IPP ........... without |
| Transit on IP Boards ...........yes |
| ticket Stat IP................. no |
| IP version..................... IPv4 |
| Transit compatibility.......... no |
| Voip Framing G711 ............. 30 ms |
| Voip Framing G723 ............. 30 ms |
| Voip Framing G729 ............. 20 ms |
| No RBT For Direct RTP H323..... no |
I have changed the Trunk COS and also GD set.
Still facing problem.
C O M P V I S U |
Latest Compvisu sys
Thu Oct 23 19:36:51 EST 2008
| C O M P V I S U |
| - G711........... yes |
| C O M P V I S U |
If I have configured wrong,Can you login to have a check on my configuration and advise
Ip Address: 203.36.12.10
Thanks for your help.
fill the realm ,account and the password in the ext gateway . use the ARS prefix to dial.
AQPS ACFE ACSE
There is no realm or account or password.There is no authentication.I have used the prefix to dial out.but still facing the problem.
New Outgoing calls traces,If this helps
Calling extension:3901 Full number:0290083901
Called number:0437407840
(1)xa000000> motortrace 2
motortrace (v5.1.0) verbosity = 0003b004
sipmotor trace-level set 2 (Medium trace).
(1)xa000000> traced
** UNIX-trace-daemon started ... (static user group No 1) **
traced started ...
1224814857 -> DECT: get_redial_nb_cells nb_cells=3 tiny=0
1224814857 -> [exec_ipc] in.
1224814857 -> [display_ipc_in] ------------ Begin ---------------
1224814857 -> neqt : 1036
1224814857 -> INVITE
1224814857 -> REQUEST URI : <> 0437407840@203.36.12.10:5060 ; user=phone
1224814857 -> FROM : <0290083901> +0290083901@203.36.12.10:5060 ; user=name
1224814857 -> TO : <> 0437407840@203.36.12.10:5060 ; user=phone
1224814857 -> CAC : 0
1224814857 -> neqt CAC : -1
1224814857 -> CLIR : 0
1224814857 -> SDP :
1224814857 -> ADDRESS : 203.36.12.2 :32514
1224814857 -> ALGOS :
1224814857 -> PCMA
1224814857 -> PCMU
1224814857 -> G723
1224814857 -> 97
1224814857 -> DIRECTION : SEND & RECEIVE
1224814857 -> N_GW_EXT : 1000
1224814857 -> [display_ipc_in] ------------- End ----------------
1224814857 -> [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the
eqt 1036.
1224814857 -> [CMotorCallManager::onIncomingEvent] New Call created.
1224814857 -> [CMotorCallManager::onIncomingEvent] eqt=1036.
1224814857 -> [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
1224814857 -> [onIncomingEvent] INVITE arrived.
1224814857 -> [receiveInviteEvent] Call: eqt: 1036 INITIAL_STATE received an ev
ent.
1224814857 -> 110b[CMotorCall::makeResponseSdp] format 97
1224814857 -> 110b[CMotorCall::new_determineTargets] try with alias.
1224814857 -> [getUrlByAlias] user=0437407840 domain=203.36.12.10.
1224814857 -> [getUrlByAlias] NOK
1224814857 -> 110b[CMotorCall::makeInitialMotorRequest]-->extGw=1000
1224814857 -> SEND MESSAGE TO NETWORK (203.36.12.10:5060 [UDP]) (BUFF LEN = 816)
INVITE sip:0437407840@203.36.12.10;user=phone SIP/2.0
Supported: replaces,100rel
User-Agent: ABS GW v5.1.0
Content-Type: application/sdp
To: <sip:0437407840@203.36.12.10;user=phone>
From: "0290083901" <sip:+0290083901@203.36.12.10>;tag=759545f456b0f992e60dc0549a
a14bff
Contact: sip:203.36.12.10
Call-ID: 44a44fd5b99faeb43d149013fe1ff30b@203.36.12.10
CSeq: 292214136 INVITE
Via: SIP/2.0/UDP 203.36.12.10;branch=z9hG4bK90f251b0f06434497eb3274cfd5b613a
Max-Forwards: 70
Content-Length: 315
v=0
o=OXE 1224814856 1224814856 IN IP4 203.36.12.10
s=abs
c=IN IP4 203.36.12.2
t=0 0
m=audio 32514 RTP/AVP 8 0 4 97
a=sendrecv
a=rtpmap:8 PCMA/8000
a=ptime:20
a=maxptime:30
a=rtpmap:0 PCMU/8000
a=ptime:20
a=maxptime:30
a=rtpmap:4 G723/8000
a=ptime:30
a=maxptime:30
a=rtpmap:97 telephone-event/8000
1224814857 -> [onIncomingEvent] CallID must be inserted.
1224814857 -> [onIncomingEvent] CallID inserted.
1224814857 -> RECEIVE MESSAGE FROM NETWORK (203.36.12.10:4135 [UDP])
a14bff
Max-Forwards: 70
Content-Length: 315
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=ptime:20
a=maxptime:30
a=ptime:30
a=maxptime:30
1224814857 -> SEND MESSAGE TO NETWORK (203.36.12.10:5060 [UDP]) (BUFF LEN = 333)
SIP/2.0 100 Trying
a14bff
Content-Length: 0
1224814857 -> 110b[CMotorCall::toGatewayOrProxy] request for proxydomain=203.36.
12.10.
1224814857 -> [isUserRegistred] getRegistration=0437407840.
1224814857 -> [isUserRegistred] result=-1.
1224814857 -> 110b[CMotorCall::onReceiveRequest] request for gateway.
1224814857 -> 110b[CMotorCall::onReceiveRequest] state = PROCEEDING_STATE.
1224814857 -> 110b[CMotorCall::methodInviteReceived] CAC = 0
1224814857 -> [receiveInviteMessage] incoming call.
1224814857 -> SEND MESSAGE TO NETWORK (203.36.12.10:5060 [UDP]) (BUFF LEN = 478)
SIP/2.0 488 Not Acceptable Here
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, SUBSCRIBE, OPTIONS
To: <sip:0437407840@203.36.12.10;user=phone>;tag=491dfd12089985ac4c9f9562fb8ac06
4
a14bff
Content-Length: 0
SIP/2.0 100 Trying
a14bff
Content-Length: 0
1224814857 -> [receiveInformationalMessage] Call: 44a44fd5b99faeb43d149013fe1ff3
0b@203.36.12.10 eqt: 1036 TERMINATED_STATE received a not handled message.
4
a14bff
Content-Length: 0
1224814857 -> SEND MESSAGE TO NETWORK (203.36.12.10:5060 [UDP]) (BUFF LEN = 399)
ACK sip:0437407840@203.36.12.10;user=phone SIP/2.0
a14bff
4
CSeq: 292214136 ACK
Content-Length: 0
1224814857 -> [receiveRequestFailureMessage] Call: 44a44fd5b99faeb43d149013fe1ff
30b@203.36.12.10 eqt: 1036 TERMINATED_STATE received a message.
1224814857 -> 110b[CMotorCall::emitEventToMonitel] content size (lginfo): 652
1224814857 -> 110b[CMotorCall::emitEventToMonitel] CAC = 0 eqtCAC = -1
1224814857 -> 110b[CMotorCall::emitEventToMonitel] Event sent on eqt : 1036
1224814857 -> [display_ipc_out] ------------ Begin ---------------
1224814857 -> REQUEST FAILURE
1224814857 -> xx : 0
1224814857 -> RELATIVE REQUEST : INVITE
1224814857 -> [display_ipc_out] ------------- End ----------------
1224814857 -> SIP EQT RELEASED
1224814857 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the
eqt 1036.
1224814857 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 1036 has r
eleased its equipment.
1224814857 -> 110b[CMotorCall::unRegister] Remove eqt : 1036 from the map.
1224814857 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1224814857 -> [CMotorCallManager::onIncomingEvent] killSession.
1224814857 -> [CMotorCallManager::onNotifyCallClosed] Call : 44a44fd5b99faeb43d1
49013fe1ff30b@203.36.12.10 is closed.
1224814857 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
a14bff
4
CSeq: 292214136 ACK
Content-Length: 0
1224814859 -> 110c[CMotorCall::~CMotorCall] Call : 44a44fd5b99faeb43d149013fe1ff
30b@203.36.12.10 is being destructed.
1224814859 -> 110b[CMotorCall::~CMotorCall] Call : 44a44fd5b99faeb43d149013fe1ff
(1)xa000000> traced
traced started ...
1224814857 -> SDP :
1224814857 -> PCMA
1224814857 -> PCMU
1224814857 -> G723
1224814857 -> 97
eqt 1036.
ent.
a14bff
Max-Forwards: 70
Content-Length: 315
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=ptime:20
a=maxptime:30
a=ptime:30
a=maxptime:30
a14bff
Max-Forwards: 70
Content-Length: 315
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=ptime:20
a=maxptime:30
a=ptime:30
a=maxptime:30
SIP/2.0 100 Trying
a14bff
Content-Length: 0
12.10.
4
a14bff
Content-Length: 0
SIP/2.0 100 Trying
a14bff
Content-Length: 0
4
a14bff
Content-Length: 0
a14bff
4
CSeq: 292214136 ACK
Content-Length: 0
eqt 1036.
a14bff
4
CSeq: 292214136 ACK
Content-Length: 0
Each time I have faced a "not acceptable here", it had nothing to do with a SIP issue, it was the call handling which refused the call (like public category issue or trunk connection category, entry not existing in real discriminator...)
I checked the Public and trunk COS and they all look good.Still facing the problem.
- cavagnaro
guru nothing....
I also sure that it is the public cos, why you say it is ok?
Hello Cavagnaro,
I also checked the COS but cant locate where I am wrong.Can you help me please.
