Dear Support,
All I have found on the search was very interisting. but I have my own problem here... maybe some of you can give me solution.
I have configure the SIP Trunk to local provider. But till now I never successfully made call from OXE to Local Number through SIP Server connection, here is my config on OXE ;
1. Direct RTP = True
2. Trunk Groups
Trunk Group Type + T2
Number Compatible With : -1
Remote Network : 3
Q931 signal variant + ISDN all countries
T2 Specificity + SIP
3. Trunk Group
Entity Number : 0
Quality Profile for Voice on IP + Always VoIP
IP compression type + G 711
Trunk Category Id : 31
Nb of digits unused (ISDN) : 0
4. Virtual Access for SIP
Trunk Group Id : 3
Number of SIP Acces : 2
5. SIP Gateway
Node Number (reserved) : 101
Instance (reserved) : 1
Subnetwork number : 3
Trunk Group : 3
IP Address : 117.xxx.xxx.xxx
Proxy Port Number : 5060
SIP Subscribe Min Duration : 1800
SIP Subscribe Max Duration : 86400
Session Timer : 1800
Min Session Timer : 900
Session Timer Method + UPDATE
DNS local domain name : -
DNS type + DNS A
First DNS IP Address : -
Second DNS IP Address : -
SDP in 18x + True
Cac SIP-SIP + False
INFO method for remote extension + False
Dynamic Payload type for dtmf : 97
6. Proxy
Initial timeout : 500
timer T2 : 4000
Dns Timer overflow : 5000
Minimal authentication method + None
Authentication realm : -
Only authenticated incoming calls + False
7. Registrar
Min expiry date : 1800
Max expiry date : 86400
8. External Gateways
Gateway Name : GW3
Remote domain : 202.xxx.xxx.xxx
Port number : 5060
Transport type + UDP
RFC3262 forced use + False
Belonging domain : -
Registration Id : -
Outgoing username : 889021000346
Outgoing Password : ****
And at the attachment was the traced.
Any advised would be appreciated.
Muchlis
SIP Trunk to Provider Never establish
Re: SIP Trunk to Provider Never establish
seems to be that the SIP provider does not answer to the OXE INVITE and after the retransmissions
the OXE stop with status 408.
Check with motortrace 3 + traced or tcpdump if the packets send out and if the provider answer
Hi Root,
Sorry I just replay your post, I wonder to know the status for 408 in OXE.
I'm using IP Phone to do this trace..
This is the traces from motortrace 3.
1244521245 -> [display_ipc_in] ------------ Begin ---------------
1244521245 -> neqt : 1036 Id : -1
1244521245 -> INVITE
1244521245 -> REQUEST URI : <> 25538226@202.xxx.xxx.102:5060 ; user=phone
1244521245 -> FROM : <33124> 33124@117.102.xxx.xxx:5060 ; user=name
1244521245 -> TO : <> 25538226@202.xxx.xxx.102:5060 ; user=phone
1244521245 -> CAC : 0
1244521245 -> neqt CAC : -1
1244521245 -> CLIR : 0
1244521245 -> N_GW_EXT : 5
1244521245 -> [display_ipc_in] ------------- End ----------------
1244521245 -> [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 1036--1.
1244521245 -> [CMotorCallManager::onIncomingEvent] New Call created.
1244521245 -> [CMotorCallManager::callFactory].
1244521245 -> [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R9.0 h1.301.25
1244521245 -> [CMotorCallManager::callFactory]=83f3a40.
1244521245 -> [CMotorCallManager::onIncomingEvent] eqt=1036 -1.
1244521245 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 1036 inserted.
1244521245 -> [quoteString] => "33124"
1244521245 -> 1118[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
1244521245 -> 1118[CMotorCall::setFilterUsedMode] To be traced = 0
1244521245 -> [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
1244521245 -> [onIncomingEvent] INVITE arrived.
1244521245 -> [receiveInviteEvent] Call: eqt: 1036 INITIAL_STATE received an event.
1244521245 -> 1118[CMotorCall::emitInviteMessage] begin.
1244521245 -> [isValidGwExt] ext gw 5 is valid
1244521245 -> 1118[CMotorCall::inviteBuildAurlWithoutBelongingDomain] P-Asserted-Identity: "33124" <sip:33124@117.102.xxx.xxx>
1244521245 -> 1118[CMotorCall::emitInviteMessage] From: "33124" <sip:33124@117.102.xxx.xxx>
1244521245 -> 1118[CMotorCall::emitInviteMessage] reqUri :sip:25538226@202.xxx.xxx.102;user=phone
1244521245 -> 1118[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=0
1244521245 -> 1118[CMotorCall::inviteBuildSupportedHeader] Invite directed to external gw : 5
1244521245 -> 1118[CMotorCall::emitInviteMessage] Request Uri : sip:25538226@202.xxx.xxx.102;user=phone
1244521245 -> 1118[CMotorCall::emitInviteMessage] To: <sip:25538226@202.xxx.xxx.102;user=phone>
1244521245 -> 1118[CMotorCall::inviteBuildContact] Contact: sip:117.102.xxx.xxx
1244521245 -> 1118[CMotorCall::emitInviteMessage] uacGatewayMode=1 uacRefresher=1.
1244521245 -> 1118[CMotorCall::new_determineTargetsForTheRequest] is not Responsible For This URI.
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] isResolution=0.
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] target is not the local node.
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] nb contacts=1.
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 25538226
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest]-->extGw=5
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] contact : sip:25538226@202.xxx.xxx.102;user=phone
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] nb available licenses=99999 .
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest]-->pSipAddSpec->getHost()=202.xxx.xxx.102
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] user= 25538226
1244521245 -> [CGWMngData::isMainServer] CPU is MAIN.
1244521245 -> [CMotorCall::makeInitialMotorRequest] count = 2.
1244521245 -> [CMotorCall::makeInitialMotorRequest] service=0 0xbffff0c8.
1244521245 -> [CMotorCall::makeInitialMotorRequest] service=1 0xbfffec0c.
1244521245 -> 1118 [CCall::makeGenericRequest] INVITE
1244521245 -> 1118 [CCall::getDialog] Confirmed Dialog is not found (ID =
1244521245 -> 1118 [CCall::getDialog] Returning Initial Dialog Client
1244521245 -> 15a9 [CDialog::createRequest]
1244521245 -> 15a9 [CDialog::buildServicesForAllRequest]
1244521245 -> 15a9 [CDialog::createInviteRequest]
1244521245 -> 21dd [CTransaction::changeState] STATE CHANGED TO INITIAL
1244521245 -> 21dd [CTransaction::changeState] notifying the parent dialog
1244521245 -> 15a9 [CDialog::onTransactionState(pTrans = 21dd, previousState = Terminated, currentState = Initial, reason = None]
1244521245 -> D18 [CRequest::CRequest] Creation of a request
1244521245 -> D18 [CMessage::send] sip_sendMessage (202.xxx.xxx.102:5060)
1244521245 -> SEND MESSAGE TO NETWORK (202.xxx.xxx.102:5060 [UDP]) (BUFF LEN = 703)
INVITE sip:25538226@202.xxx.xxx.102;user=phone SIP/2.0
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
Require: 100rel
Supported: replaces,timer
User-Agent: OmniPCX Enterprise R9.0 h1.301.25
Session-Expires: 2400;refresher=uac
Min-SE: 300
From: "33124" <sip:33124@117.102.xxx.xxx>;tag=08e08fb74a9xxxb28fe5c08c0e78xxx177
Contact: <sip:117.102.xxx.xxx;transport=UDP>
Call-ID: 6739fad8xxx6fb0db83f53630c9cc8ba1@117.102.xxx.xxx
CSeq: 1757611620 INVITE
Via: SIP/2.0/UDP 117.102.xxx.xxx;branch=z9hG4bK95e2528d145a4525b8651cef4785d443
Max-Forwards: 70
Content-Length: 0
1244521245 -> 21dd [CTransInitialState::createRequest] Transaction changes to Calling state
1244521245 -> 21dd [CTransaction::changeState] STATE CHANGED TO CALLING
1244521245 -> 15a9 [CDialog::onTransactionState(pTrans = 21dd, previousState = Initial, currentState = Calling, reason = Request creation]
1244521245 -> 21dd [CTransaction::startTimer] Timer A is started (delay = 500 ms)
1244521245 -> 21dd [CTransaction::startTimer] Timer B is started (delay = 8000 ms)
1244521245 -> 15a9 [CDialog::addTransaction] added transaction 21dd with branch z9hG4bK95e2528d145a4525b8651cef4785d443, with CSeq 1757611620
1244521245 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
1244521245 -> [CSessionTimerContext::updateAfterRefreshCreation] Update CSessionTimerContext (refresh creation)
1244521245 -> [CSessionTimerContext::updateSupported] Request timer supported
1244521245 -> [CSessionTimerContext::updateMinSE] Min-SE updated : 300
1244521245 -> [CSessionTimerContext::updateSessionExpires] Refresher updated : i
1244521245 -> [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 2400
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] nb contact=1.
1244521245 -> [CForkedBranch::CForkedBranch] context = 0x83f3e54.
1244521245 -> 1118[CMotorCall::branchAllocation] built branch number=1.
1244521245 -> 1118[CMotorCall::branchAllocation] pForkedBranch = 0x83fc208.
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] reqUri duplication pForkedBranch = 0x83fc208.
1244521245 -> 1118[CMotorCall::makeInitialMotorRequest] reqUri duplication2.
1244521245 -> [CForkedBranch::reqUriDuplication] reqUri :sip:25538226@202.xxx.xxx.102;user=phone
1244521245 -> [onIncomingEvent] CallID must be inserted.
1244521245 -> [onIncomingEvent] CallID inserted.
1244521245 -> [exec_ipc] in end 957.
1244521245 -> RECEIVE MESSAGE FROM NETWORK (202.xxx.xxx.102:5060 [UDP])
SIP/2.0 100 trying -- your call is important to us
Server: Sip EXpress router (0.9.6 (i386/freebsd))
Content-Length: 0
1244521245 -> [CIOCom::receiveResponse] CResponse 714 ref=1
1244521245 -> [CDispatcher::onIncomingResponse]
1244521245 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1244521245 -> 102 [CCallManager::onIncomingResponse]
1244521245 -> 1118 [CCall::receiveResponse] 100
1244521245 -> 1118 [CCall::receiveResponse]Trying to find the right dialog
1244521245 -> 1118 [CCall::getDialog] Confirmed Dialog is not found (ID = 08e08fb74a9xxxb28fe5c08c0e78xxx177;)
1244521245 -> 1118 [CCall::receiveResponse]One dialog found
1244521245 -> 15a9 [CDialog::receiveResponse]
1244521245 -> 21dd [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding state
1244521245 -> 21dd [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1244521245 -> 15a9 [CDialog::onTransactionState(pTrans = 21dd, previousState = Calling, currentState = Proceeding, reason = 1xx response reception]
1244521245 -> 21dd [CTransaction::freeTimerToken] Timer A is freed
1244521245 -> 21dd [CTransaction::freeTimerToken] Timer B is freed
1244521245 -> 1118[CMotorCall::searchForkedBranch]pForkedBranch=0x83fc208.
1244521245 -> [receiveInformationalMessage] Call: 6739fad8xxx6fb0db83f53630c9cc8ba1@117.102.xxx.xxx eqt: 1036 PROCEEDING_STATE received a message.
SIP/2.0 500 Server internal error (TM)
Record-Route: <sip:202.xxx.xxx.102;ftag=08e08fb74a9xxxb28fe5c08c0e78xxx177;lr>
From: 33124 <sip:33124@117.102.xxx.xxx>;tag=08e08fb74a9xxxb28fe5c08c0e78xxx177
Server: Sippy
1244521245 -> [CIOCom::receiveResponse] CResponse 715 ref=1
1244521245 -> 1118 [CCall::receiveResponse] 500
1244521245 -> 714 [~CResponse] resp(100) 6739fad8xxx6fb0db83f53630c9cc8ba1@117.102.xxx.xxx 1757611620 INVITE
1244521245 -> 21dd [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
1244521245 -> 21dd [CTransaction::changeState] STATE CHANGED TO COMPLETED
1244521245 -> 15a9 [CDialog::onTransactionState(pTrans = 21dd, previousState = Proceeding, currentState = Completed, reason = Final resp reception]
1244521245 -> D19 [CRequest::CRequest] Creation of a request
1244521245 -> D19 [CMessage::send] sip_sendMessage (202.xxx.xxx.102:5060)
1244521245 -> SEND MESSAGE TO NETWORK (202.xxx.xxx.102:5060 [UDP]) (BUFF LEN = 360)
ACK sip:25538226@202.xxx.xxx.102;user=phone SIP/2.0
CSeq: 1757611620 ACK
Content-Length: 0
1244521245 -> 21dd [CTransaction::startTimer] Timer D is started (delay = 32154 ms)
1244521245 -> 15a9 [CDialog::updateRouteSet] there are 1 record-route headers
1244521245 -> [CForkedBranch::setFinalResponse] pResponse=0x83fbcd0.
1244521245 -> [CForkedBranch::setFinalResponse] response=500.
1244521245 -> 1118[CMotorCall::responseToInviteOrCancel] no response to the CH m_cancelSent=0.
1244521245 -> 1118[CMotorCall::responseToInviteOrCancel] all responses are received 1.
1244521245 -> 1118[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
1244521245 -> 1118[CMotorCall::chooseBestResponse] pForkedBranch=0x83fc208 iResponseCode=2000.
1244521245 -> [CForkedBranch::getResponseCode] response=500.
1244521245 -> 1118[CMotorCall::chooseBestResponse] last iResponseCode=500.
1244521245 -> 1118[CMotorCall::chooseBestResponse] next branch.
1244521245 -> 1118[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
1244521245 -> [receiveServerFailureMessage] Call: 6739fad8xxx6fb0db83f53630c9cc8ba1@117.102.xxx.xxx eqt: 1036 PROCEEDING_STATE received a message.
1244521245 -> 1118[emitEventToMonitel] content size (lginfo): 656
1244521245 -> 1118[emitEventToMonitel] CAC = 0 eqtCAC = -1
1244521246 -> [ipc_thread] IPC Thread : Ipc reception 958.
1244521246 -> [ipc_thread] IPC Thread : TCL thread signaled.
1244521246 -> [sendLgEvtSip] Event sent on eqt : 1036 Id :-1
1244521246 -> [display_ipc_out] ------------ Begin ---------------
1244521246 -> Id : -1
1244521246 -> SERVER FAILURE
1244521246 -> xx : 0
1244521246 -> RELATIVE REQUEST : INVITE
1244521246 -> [display_ipc_out] ------------- End ----------------
1244521246 -> 1118[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
1244521246 -> 1118[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
1244521246 -> [CForkedBranch::getResponseCode] response=500.
1244521246 -> [exec_ipc] in 957.
1244521246 -> [display_ipc_in] ------------ Begin ---------------
1244521246 -> neqt : 1036 Id : -1
1244521246 -> SIP EQT RELEASED
1244521246 -> [display_ipc_in] ------------- End ----------------
1244521246 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1036--1.
1244521246 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 1036 has released its equipment.
1244521246 -> 1118[CMotorCall::emitSipEqtReleaseAck] SIP_EQT_RELEASE_ACK
1244521246 -> 1118[emitEventToMonitel] content size (lginfo): 656
1244521246 -> 1118[emitEventToMonitel] CAC = 0 eqtCAC = -1
1244521246 -> UNKNOWN MESSAGE
1244521246 -> 1118[CMotorCall::unRegister] Remove eqt : 1036 diag : -1 from the map.
1244521246 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 1036 erased.
1244521246 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1244521246 -> [CMotorCallManager::onIncomingEvent] killSession.
1244521246 -> 1118 [CCall::killSession]
1244521246 -> 21dd [CTransaction::changeState] STATE CHANGED TO TERMINATED
1244521246 -> 21dd [CTransaction::freeTimerToken] Timer D is freed
1244521246 -> 21dd [CTransaction::changeState] no transaction state, terminated reason : None
1244521246 -> 1118 [CCall::killSession] notifying the call manager
1244521246 -> 102 [CCallManager::onCallClosed]
1244521246 -> 102 [CCallManager::onCallClosed()] Call 1118 closed. Removing call 138361408 from the maps
1244521246 -> [CMotorCallManager::onNotifyCallClosed] Call : 6739fad8xxx6fb0db83f53630c9cc8ba1@117.102.xxx.xxx is closed.
1244521246 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1244521246 -> [exec_ipc] in end 957.
1244521246 -> [CTransaction::notifyDialog]
1244521246 -> [CTransaction::notifyDialog] notify parent dialog
1244521246 -> 15a9 [CDialog::onTransactionState(pTrans = 21dd, previousState = null, currentState = Terminated, reason = None]
1244521246 -> 15a9 [CDialog::onTransactionState] dialog is terminated
1244521246 -> 15a9 [CDialog::onTransactionState] onDialogClosed
1244521246 -> 1118 [CCall::onDialogClosed]
1244521246 -> 1118 [CCall::onDialogClosed] only initial *********
1244521246 -> 1118 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
1244521246 -> D19 [~CRequest] req 6739fad8xxx6fb0db83f53630c9cc8ba1@117.102.xxx.xxx 1757611620 ACK
1244521246 -> 102 [CCallManager::removeGarbage] at index i = 0
1244521246 -> 1118[CMotorCall::~CMotorCall] Call : 6739fad8xxx6fb0db83f53630c9cc8ba1@117.102.xxx.xxx is being destructed.
1244521246 -> 715 [~CResponse] resp(500) 6739fad8xxx6fb0db83f53630c9cc8ba1@117.102.xxx.xxx 1757611620 INVITE
1244521246 -> 1118 [CCall::~CCall]
1244521246 -> 1118 [CCall::removeGarbage]
1244521246 -> 15a9 [CDialog::~CDialog]
1244521246 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1244521246 -> D18 [~CRequest] req 6739fad8xxx6fb0db83f53630c9cc8ba1@117.102.xxx.xxx 1757611620 INVITE
1244521247 -> TFTPD:===== TFTPD RUNTIME STATISTICS =====
1244521247 -> TFTPD: MAX CONTEXT USED : 0
1244521247 -> TFTPD: TOTAL NBR OF TIMEOUTS : 0
1244521247 -> TFTPD: TOTAL NBR OF TRANFER FAILURES : 0
1244521247 -> TFTPD: TOTAL NBR OF TRANFERS REFUSED : 0
1244521247 -> TFTPD: TOTAL NBR OF START REFUSED : 0
1244521247 -> TFTPD: TOTAL NBR OF START REFUSED (scs cause) : 0
1244521247 -> TFTPD:tftpd activity normal end.
1244521247 -> TFTPD:tftpd activity end.
msmuch
Require: 100rel
Min-SE: 300
Max-Forwards: 70
Content-Length: 0
Content-Length: 0
Server: Sippy
Content-Length: 0
msmuch
In the first provided trace we've seen an outgoing INVITE with SDP to the carrier,
but in the new trace OXE send INVITE without SDP to the carrier and the carrier
proxy reject the call with "500 Server internal error". You should ask the carrier
why his Sippy B2BUA / SER does reject the call and also check in OXE why the
SDP is missing now? Other set type as before? Is minimum one GD/INTIP is in service?
What happens on incoming calls?
Hi root,
GD already in service status, and for incoming and outgoing still can not. I have ask the provider about 500 serverinternal error, but they can not explain for this.
Hi root,
it's very strange, I just create another trunk and try to route the call. It works and OXE can send SDP.
anyway thanks for the discussion.
