OXE 9.0 (with SIP) + GVP 7.6 + omni genesys
A H323 and SIP forum only !
thkim81
Post by thkim81 » 27 Oct 2009 08:20
Hi!
I setting the OXE 9.0 and sIP trunk setting
also IVR is GVP 7.6 (IP IVR) with sIP trunk
and I testing interlock OXE + GVP
I prepared the manual and reference the manual
(GVP SIP 7.6 connected to ALCATEL OmniPCX4400 with manual components
installation. INSTALLATION AND CONFIGURATION GUIDE)
i reading the manual. i have one question.
page 13 is write.
5.1) Configure OmniPcx Enterpise SIP ports
Hardware requirements
CPU7 or Appliance Server is mandatory for this integration.
1SIP access uses 1 compressor, which is available on INT-IP daughter board, or Media Gateway
daughter board.
2 possible daughter boards per INT_IP
- GIP-6 card has 30 compressors
- GIP-6-A card has 8 compressors
- GIP 4-4 card has 30 compressors
Some compressors are reserved by the system.
i checked the my site INT IP board
i have two INT IP board . one is daughter is 2 GVP 4-1 and another is nothing.
can you explain the manual expression ? i don't know the mean
i can't the interlock GVP . or can complex.?
Return to “H323 / Sip”
