RequstId in OnRoutingStateChanged
ssteiner
Post by ssteiner »
As per the object model, OnRoutingStateChanged contains a requestId string which is used to correlate requests and responses.
However, the object model of SetRoutesRequest, SetOverflowRoutesrequest and SetForwardRoutesRequest does not contain such a requestId parameter.
So, what's the point of requestId in OnRoutingStateChanged? I hope it's an oversight in the Set* models as this was a very useful thing that I was making use of quite frequently on OTMS.
yblanchard
Re: RequstId in OnRoutingStateChanged
Post by yblanchard »
It's a documentation bug(not cleaned from OT): requestId is not supported on O2G. There is no secured mean to make a correlation between the CMIS event received from OXE and a previous request.
==> to be removed from the documentation
ssteiner
Post by ssteiner »
Snif… would have made my life a LOT easier having that.
ssteiner
Post by ssteiner »
could it be that this feature is also broken on OTMS? I have a scenario where I could use it, yet, despite sending a requestId for every of my routing request, nothing is ever returned in OnRoutingStateChanged
yblanchard
a case should be opened on OTMS to determine if this feature is really broken on OTMS or if it's a local issue
Return to “O2G”
