Change Country in ACTIS
I have an OLD version installed in my PC , i remove it and try to install new one R18 , but i'm still getting the same country market , before i were given the option to select countries..how can i change the ACTIS market
Re: Change Country in ACTIS
Please
Hve You tried to install in another directory? Maybe some files kept after old ACTIS uninstall?
Thanks ,
Yes i can get the old items , what i want is to change the market from Saudi Arabia to Sudan , i remember before i can select one of them but now i have only one country , i have put the Prefix for Sudan .
is there possibilities to add another country
- cavagnaro
No you can't add another country as a BP works inside a country only. Your case seems an exception. Maybe install on another PC what you need.
Thanks alot , i moved from KSA to Sudan to a different BP and i uninstall the OLD ACTIS and re-install new one but can't get the new country, still getting OLD one , changing the PC is difficult .
- cavagnaro
Install on another folder. Check the windows registry for old keys and delete them too
