Hi Gents,
having an issue with adding a new OXE expansion_1 shelf. Current SW version is F4.401.13. After entering the required config data OXE replying with the message:
**no more memory space (REMANENT)**
Looks like we have an issue with the OPS files.
I have raised a case with alcatel, but would be graceful for any suggestions.
No more memory space (remanent)
Re: No more free memory (remanent)
check on the oxe,
> cdmao
> cfgUpdate
and check the value of 10 and also 41.
What are the type of incidents do you see on the system ??
Which shelf are you trying to create ?
check on the oxe,
> cdmao
> cfgUpdate
> cfgUpdate
--para 10 is 2 now. I also increased it up to 3 before at the same time as I increased para41 up to 20,000.
--para 41 was 17,xxx and now is 25,000
31/07/07 14:22:11 015010M|--/--/-/---|=2:4353=Initrem:Lack of memory, table HARDCONF cause cnx_alloc infos -1 -1 -1
31/07/07 14:22:11 015010M|--/--/-/---|=2:2018=No more free connection object, type 161, neqt PO -1
--MG Large expansion_1 from shelf 1
- frank
Re: No more memory space (remanent)
Did you reboot after you modified the cfgUpdate ?
Also, how many users do you have for real, and what's the value of para 1 ?
--yes, system was rebooted.
--para1 (Extensions) is 125 and for real is 24 (mgr/users/all).
installed an empty DB today and put on top the backup, result is same. also installed the latest static and dynamic patches. doesn't help.
fixed.
Change para11 (cd /usr3/mao; command cfgUpdate) from 100 to 200.
thanks Guys.
thanks Guys.
- frank
In your previous post, you said that para1 was 125 ..!?
