Assistant for Network Configuration
Alcatel Configuration Tool for International Sales -all ACTIS related topics, how-to's, tips and tricks.
EGC
Post by EGC » 16 Mar 2015 10:56
I remember that there used to be an assistant for network configuration taht let you create configurations based on requirements that generated a BOM; this way you chose i.e. the number of ports, their speed and some other specifications and Actis would suggest the switch model, the SFP's and so on.
This was very useful for presales not very expert on Network configurations to generate simple quotes.
In latest releases of Actis, I can find the option but is always disabled. Do you know if there is any way to enable this assistant?
Thank you in advance.
EGC
Re: Assistant for Network Configuration
Post by EGC » 28 Apr 2015 10:17
Well, I will answer myself. Unfortunately, the network wizard is no longer available since its development has stopped.
Return to “Actis”
