has anybody tryed to search a Document in the "new" -Technical Documentation Section on BPWS?
ALU has remoddeled it, so you can't find ANYTHING.
You could set Filters, but you can't find the Document you are searching.
Example:
Search for "configuration Sip Trunk Group" in the old Technical Documentation Section you got the Config Guide for a Sip TG...
In the New one, you get everything but no Config Guide...
Has anyone an Idea how to set Filters in the right way?
Other: I am a German Technican, but there are no German Docus online. But the Preselected Language is German.... I have
to Change it everytime....
BPWS new Document search Section.... What the F***
- cavagnaro
Re: BPWS new Document search Section.... What the F***
About the language go to your profile and change your settings to English, it is better always. You will not find all docs in your language.
About the redesign...well...we can yell as much as we want here, but here is not the best place to complain about, open an eSR on Web issues for them
Just select "OmniPCX Enterprise" and type "SIP trunk group" in the search box, you get what you want. No ?
ACSE OmniTouch CCIVR (2014/05)
ACSE OmniPCX Enterprise R11 (2013/12)
ACSE OmniTouch Contact Centers Standard Edition (2013/11)
ACSE OmniPCX Enterprise R10 (2012/06)
ACSE OmniTouch Contact Centers Outbound R10 (2011/06)
what disturbs is, that there was no information about the new document-libary. so i was on a customer site and had to look about something and BANG.... there was this new document-system...
but on the other hand... as the previous document-system was going online... it was not perfect too... and we had to learn to live with them...
it is just different as before...
btw... has anybody here a quick way to download all the documents?
regards...
regards...
