OmniAccess 4308 problem with boot config
Locked
ExSter
Post by ExSter »
Hi !
I've some problem with my OmniAccess 4308 Switch when I boot it.
I got the following text : "Cannot decrypt the password". And then, I can't enter in the configuration...
I press any key at boot time, and got the cpboot> prompt, but I don't know how to reset my config to enter again in the switch configuration...
Could you tell me how to reset it or to do a password recovery ?
Thanks.
krzysioD
Re: OmniAccess 4308 problem with boot config
Post by krzysioD »
Try downloading docs from bpws, there is explanation how to reset password.
and proably, upgrade your switch to the newest firmware.
ExSter
Post by ExSter »
krzysioD wrote:Try downloading docs from bpws, there is explanation how to reset password.
Hi !
Many thanks for your answer.
But, what's BPWS ?
I got docs from the original CD : "Alcatel-Lucent OmniAccess Wireless Essentials 3.1" , but nothing about password recovering.
Where can I get this docs you talk me about to ?
ExSter
Post by ExSter »
Business Partners Website, ok.
I'll ask an access to my colleague, because I don't have it atm :(
Locked
Return to “OmniAccess WLAN Switching Systems”
