Dialer 2.0
Re: Dialer 2.0
Tried to download the dialer software but unfortunately the link is said not available anymore. Any chance that i can download the file?
Thank you
Thank you
Re: Dialer 2.0
very usefull when configure network between OXE, as say, any chance to download the file ?
Re: Dialer 2.0
I the same way try use dialer on the node with Rel. 9.1.
Unfortunately on Rel. 9.1 dialer not working.
Re: Dialer 2.0
I have the same problem: DIALER not working on rel.9.1
Is there any chance for an update? Mr. Frank Gadot
DIALER - Made by Frank Gadot - frank@alcatelunleashed.com
thx
thx
Re: Dialer 2.0
I have no problem with the dialer and R9.1 (i1.605.25a)
Re: Dialer 2.0
Yes, I now
it works with that cmd:
./dialer
thx
./dialer
thx
- Tha Tawa'S
Re: Dialer 2.0
The file is not on line anymore ???
I really would like to test it. is it possible to add it again ?
Thx
Thx
Re: Dialer 2.0
enjoy
