4059 pc based console
mr.alcatel
Post by mr.alcatel »
dear frnds,
in 4059 operator while using the line , if an incoming call, the existing call getting low volume..?
on speaker mode/handset mode/headser mode.......is there any solution..?
Eliott
Post by Eliott »
Normally the volume should decrease during the camp-on signal only.
After the signal the call volume should go back to the original level.
Is it reproducible?
Has the Flag "Tone Presence / Tone Monitoring" in Attendant set an effect?
MTConsulting
Post by MTConsulting »
is this the proper 4059 MAC/PAC or that horrible joke, the 4059 IP??
You don;t like the IP version ?
I think it's less headaches than the old MAC/PAC :D
MTConsulting
less headaches? for who? The user of the 4059IP now has to use a keyboard, a mouse, a handset and a telephone??
4059 MAC/PAC = mouse + keyboard only.
4059IP = cheap ass Alcatel cutting costs.
Mr T
Post by Mr T »
I agree with Frank, the MAC/PAC was always a pain in the ass. No customers would ever buy the PC from Alcatel and always ran into compatibility issues. 4059 IP doesn't have PC compatibility issues.
MTConsulting
how is buying a PC with a serial port or installing a serial card a pain in the ass vs now needing 4 arms to drive the stupid IP system? I think you haven't seen a MAC/PAC installed properly? I worked with staff who had the old system and now spew about the 'new' and 'better' system. I old keyboards were ideal for business that employed handicapped staff as operators and the new system is no good for them either.
Mr T
Post by Mr T »
The only difference is you have an 8 or 9 series phone that is your handset or headset instead of the handset or headset connecting to the keyboard.
I have plenty of MAC/PAC's still out there and working fine...I just hated dealing with the serial connection and drivers.
To each their own.
swinstu
Re: 4059 pc based console
Post by swinstu »
Does the 4059IP with a 4029 (voice path) support volume control for ringing? The volumne increase and decrease on the keyboard makes no difference and the volume on the 4029 cannot be changed when in attendant mode?
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
Eliott
Post by Eliott »
I think it was configurable in the 4059 settings. F11? Can't remember it. Melody and Level can be adjusted there. Userguide?
Return to “Entities”
