I have a release 9.1 4400 with SEPLOS extensions (SIP extensions)defined. When the SIP Clients are off-line, internal callers see an Out-Service condition. External callers roll to the entity's CDT for processing.
Setup: system==>other system parameters=>sytem OOS to entity "1" and
tele-COS paramter "rights to forward if MIPT/IP is out of service" set to
1. For SIP exxtensions: Is there anyway to overflow internall callers to the associated set..
Thanks...
SIP extensions rolling OOS when cleint off-line
Re: SIP extensions rolling OOS when cleint off-line
HI, this feature is released in R10 in the phone features COS. overflows to the associate number.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Thanks for info...
One furhter particular question on the release-10 functionality; if the assocaited set is the voicemail pilot number and the set is confirgured with voicemail, will an internal incomming it roll the call to VM if the set is OOS. Thanks...
from the description yes but I have not actually tested it myself. maybe someone else has.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Thanks Murray...
