Error with OV2500&2700
Hi There...
Working with OmniVista 2500&2700 v3.4, this message appears when I try to login:
Login Failed on Server X.X.X.X port 1127. Exception creating connection to: X.X.X.X.
Socket operation on nonsocket: connect.
Whats that mean?
Thanks in advanced...
Piter
Whats that mean?
Piter
Re: Error with OV2500&2700
May be PR# 168302 in Release Notes?
Thanks...
That´s the error with OV, but in the RN says "After a Few Minutes of Inactivity When Logging In", but in my case I cannot login.
When I try to log in Omnivista, the error appears (no previous login).
It´s not an upgrade...
My OS is Windows Server 2008 Standard Edition... HDD = 146 GB / RAM = 4 GB / CPU = 3.6 GHz / 32 bits OS.
According with RN, the system requirements are OK.
I´ve uninstalled and installed again OV, but the error still appears.
I tried to install OV 3.4 32 bit on Windows 2008 64bit on VBox with no such issue, see attached (simply unzip and open in browser).
OK one6f...
Let me check and post it later...
Thank you very much!!!!
Hi There...
I installed OV 3.4.1 according the swf file on Windows 2008 Server on a common PC (without working in a production environment) and everything OK until I restored a backup file of my original server.
I can see that the omnivista services on Windows (services.msc) are offline.
Can be a problem with the backup file???
Hi, junquel, could you solve the problem? I have the same problem and I haven't been able to solve it. I see another user posted some files and you thanked him for it, but I don't get them because I do not have enough permissions. Thanks,
Hi jdvillalobos....
Sorry for delay. I didnt seeing your post.
So, unfortunately, I didnt. O i dont know yet.
First, my OV server had the following: 4 GB RAM and 3 GHz processor, 160 GB HDD and Windows Server 2008 SP1 installed.
I had to install on the hardware Windows Server 2003 Enterprise Edition. So far, i dont have any troubles.
Deactivated Windows Firewall, and turn off automatic updates (windows and java).
Take a look the OmniVista Release Notes. Depending on your version, you must have a X operating system (Windows and AOS switches).
In my case, the version OV 6.3.1 supports up AOS 6.3.1 and no Windows Server 2008. According the RN.
In all my switches I have 6.3.4 R01... Maybe thats the problem??? I dont know. I am still working on it.
I hope be useful.
Please, if you have a solution, post it!!!..
I hope be useful.
I have this error but my windows version is 2012 R2
Thanks.
Thanks.
