4080 IP DECT with AP300
Papa_Osteel
Post by Papa_Osteel »
Hye all,
i've got a DAP 300 nec and it worked fine until 3 days. I don't know what i did in DAP controller server but my DAP don't send any bootp or tftp message. She 's turn on (green light fixed)and she keep her old IP address (with http access and telnet).
How can "reset" the DECT Access Point ?
Can we connect throw telnet or ftp? whith witch login / password?
and what can we doing with this access?
thanks
ps: sorry for my english , i'm french... lol ;)
Papa_Osteel
Re: 4080 IP DECT with AP300
in fact, i want to know if it's possible to do a factory reset of the access point ? and how ?
best regards.
Eliott
Post by Eliott »
Change the flag to load the dapcfg.txt with next Boot in the DAP Configurator. (Not store on flash)
I had the same problem in my Lab but can not exactly remember the solution but I think the above one was it.
Papa_Osteel
thanks
but no effect.
the AP doesn't send bootp message so no tftp upload.
The AP start like she was alone on the LAN
MTConsulting
Post by MTConsulting »
Sorry to hear you got stuck using this crappy DECT system Papa.
It is an absolute dog of a thing, if you can install real IBS DECT instead you will have 0% head aches with that.
hedebal
Post by hedebal »
Hi everyone.
I have a NEC AP300 and I am trying to get it working on my Acatel omniPCX 10.3.13.1 through the OMC 10.3/13.1a
went to: IP Dect - DAP configurator - Misc setting, and checked that the PARI number is there.
Connected the Nec AP300 to the same Vlan as the PCX .
The Nec Ap300 comes alive with both lights flashing, the amber flash faster then the green then it goes of and come back the the Nec restart.
Can any one help, please.
Return to “PWT/DECT System”
