Connecting Alcatel Oxe R10.1 with Asterisk trough ISDN
HannesR
Post by HannesR »
Hello all,
I'm trying to make a connection between an alcatel oxe pabx and asterisk via ISDN and a Patton gateway trough a formerly used isdn breakout. I searched on this forum, and already read some good manuals and posts, but at this moment i'm stuck on this...
Main goal is to make internal calls between oxe and asterisk and make public calls with the asterisk over the oxe.
On the oxe there are currently 2 trunks, 1 PRA-30 (main trunk) and a second trunk (the trunk currently in use to make the link between the two pabx'es with the patton)
The patton and the asterisk are already configured,. I can set up a call from asterisk to all alcatel phones, that works fine. When i try to make an external call, the call goes to a internal nummer on the alcatel pabx.
Another thing that isn't working is call internally from alcatel to asterisk phones. I tried to make a second prefix and routing, but i don't really get it how this works. (i'm not an alcatel specialist and work with omnivista to configure everything)
Does somebody have experience or a good manual to make this setup working? Most information here handles about a sip trunk between oxe and asterisk.
Thanks for the feedback!
Re: Connecting Alcatel Oxe R10.1 with Asterisk trough ISDN
hi
what's your external prefix to seize the main trunk (it should be same at both ) if 0 at oxe it should be same at asterisk ; you should well manage the prefixes (as exteanlfrom asterist call goes to internal oxe)
authorise transit call Conection cos 5 with 5 =1
for routing call from oxe to asterist with prefix and routing
go to translator prefix plan
create for exemple 59 >>>>or other wicth correspending to asterisk user dir
routing number
network: other than oxe network (mainly #0)
trunk : number of the second trunk with patton
number of digit : according to asterisk user of digit fro exemple if 5 (59 should be a part of it so 59xxx)
also post t3 trace for internal and external call at oxe side
HannesR
Post by HannesR »
Hi Haroun,
Thanks for your reply! The problem is already solved:There was a wrong routing in the patton gateway.
Everything works fine now!
good you're wellcomed
moelhawa
Post by moelhawa »
I have a problem in calling from OXE to Asterisk, but calls from Asterisk to Alcatel is fine.
where I can get [ transit call Conection cos 5 with 5 =1 ]
also when I dial 1 (the start of Asteris extension) it gives me on the handset "Replace Handset".
tgn
Post by tgn »
change the connection cos 5 (mgr/categories/connection cos)
take a look in the oxe numbering plan. (mgr/translator/numbering plan)
regards...
--- back to basics... focus your eyes on the essential things... ---
Return to “Asterisk”
