OTMS and iPhone with standart user
lapepe
Post by lapepe »
We have OTMS 1.3 and 2.0 with licence - look at the attachements.
Several times I read both documents (OTMS 1.3 and 2.0).
The documentation only describes the Alcatel-Lucent Enterprise OpenTouch Conversation for iPhone.
https://itunes.apple.com/gb/app/alcatel ... 47970?mt=8
Quoting from the documentation... The Alcatel-Lucent OpenTouch Conversation for iPhone can only operate with an OpenTouch server R1.3 MD1+ and is only available for OpenTouch users.
We require iPhone function with standard users in OXE !!
We can use Alcatel-Lucent OmniTouch 8600 My Instant Communicator ??
https://itunes.apple.com/us/app/alcatel ... 88038?mt=8
We tested this application, but does not work- look at the attachements.
First step configure iPhone connection via local WiFi with OTMS.
Maybe we have something wrong in the configuration.
How, where configure this application in OTMS 1.3 or OTMS 2.0 ??
How do I specify the server address ??
https://MyServerName/DM
This does not work.
When i put this url to browser...
https://MyServerName/DM/Iphone/MACiPhone.xml
https://MyServerName/DM/Iphone/CommonConfig.xml
... look configure OK (same as Android).
Android working well with...
Any idea ??
Best regards, Josef.
LaPEPE
jasic
Re: OTMS and iPhone with standart user
Post by jasic »
You need to install the IPhone proxy on a second system. Look at TC 1323.
lapepe
Post by lapepe »
Hi Jasic, today at morning i read TC 1323.
I searched software (iPhone Gateway, or iPhone proxy, or iPhone WebProxy) in ALU business portal and i have not found anything.
Where should I look ??
Where can I download the software ??
LaPEPE
jasic
Post by jasic »
Hi ,
it's located under the OmniMobility Folder.
You need the one for dedicated server.
Alcatel-Lucent OmniTouch 8600 My Instant Communicator for iPhone
iPhone MyICsWebProxy (dedicated server Gateway) - R3.2...
8.57 MB
lapepe
Post by lapepe »
Thanks a lot.
I read "TC1218_Release_Note_OmniPCX_Enterprise_MIC_Mobile_client_en-Ed17.pdf".
Can i install "proxy-1.1.4-1.i386.rpm" direct to OTMS server ??
And "gateway-1.1.3-1.i386.rpm" in to dedicated server ??
Look at posted attachments.
LaPEPE
jasic
Post by jasic »
No the Proxy Version is only for the ICS. For OT you need the Gateway Version on a dedicated server.
Return to “OTMS - OpenTouch Multimedia Services”
