Meet me confrence
Meet me confrence
Post by 10111989 »
Dear All,
I have just facing issue in meet me conference when i have organised the conference call i have maximum connected 6 person conf call so how can i increase the no of call .
I have 29 party conf call licence .
Second Issue- If i used disha how many outside users connected in meet me conference.
Please anybody suggest me ASAP
Warm Regards
Gaurav Singh
Re: Meet me confrence
Check the system documentation. It is well documented.
You need to manage the System-->Other syst parameters -->System parameters --> N Conference modularity
For conference (common hardware - GD/GA boards) you need to divide board recourses between VoIP and conference - you need to declare number of conference/compressors in board parameters and for conference size - you have system parameters (written in post above)
For external user - check System, item Max Nb Trunks Conf.N
For DISA - user can enter in conference only after substitution (manual or automatic). Direct feature prefix dialling after DISA - forbidden.
For external user with disa, a parameter should be checked before :the external line type connected to the PABX should be taken in consideration. NDDI line will inject lot of noise witch will increase each time a new disa user will be connected to the conf , playing the nddi parameters under ALU control has not solved issue even changing the GPA BOARD with GPA 2 one . if you use digital lines (isdn,PCM, ip , sip ) you're safein this case ; only check system & disa parameters as VAD Sayd
10111989
Post by 10111989 »
Thanks all of you.
I have solve the issue successfully now i am able to do a 29 party conference .
But
Regarding the disha my query is
how many no of users (Mobile users) externally join the meet me conference ?
If i take the disha licence .
Warm Regards
Gaurav Singh
i think disa licence has one value authorized or not
disa
check the value under spadmin option 2
12 DISA = 1
for external user mobileusers check System, item Max Nb Trunks Conf.N , test & try increse the number one by one and don't forgot anyway you need at least one internal participant to keep the trunks on conf
hoppsergpunkt
Post by hoppsergpunkt »
where can i find:
" System, item Max Nb Trunks Conf.N "
in OmniVista 8770 ???
Many thanks...
When you configure PBX.
Edit "System"
Item "item Max Nb Trunks Conf.N"
