Overflow to Voicemail
TDV
Post by TDV »
Hi I've configured a Hunt group with overflow to a number which is forwarded to it's voicemail.
When calling internally and the group is "empty" I get the voicemail.
However when I call from external line I get the busy tone.
I want external callers to reach the voicemail when there is no answer or the group is empty.
What can I do?
thx
Re: Overflow to Voicemail
Public Network COS used in HG - Overflow on total busy managed or not?
TDV
Post by TDV »
Hi Vlad. Thx!
It was idd set to 0.
Adapted it and now it works!
thanks a lot for your quick response!
Return to “Groups”
