Ominivta 8870 Adminnmc Acount locked
This application replaces the OmniVista 4760
rolfo333
Re: Ominivta 8870 Adminnmc Acount locked
Post by rolfo333 »
I tested this on one of my systems and it works.
Just one comment: The two mentioned services "Sun Directory Server .." were renamed into "Oracle Directory Server ...".
It is probably better to boot the entire server in step 6 and not only the 2 services.
After changing the directory manager password again in order to encrypt it, you can run ToolSOmniVista again in order to reset you adminnmc password or any other administrator password.
Br
rolfo333
tgn
Post by tgn »
very helpful. thanks for sharing.
b^.^d for doublezero.
regards...
--- back to basics... focus your eyes on the essential things... ---
mejust
Post by mejust »
Doublezero
Thanks a million , I´m back in control :-)
Rolof333 is also right :
After changing the directory manager password again in order to encrypt it, you can run ToolSOmniVista again in order to reset you adminnmc password or any other administrator password. ""
It seems like many users had the same problem.
Thanks you Thank you
Rgds
mejust
doublezero
Post by doublezero »
rolfo333 wrote:Hello,
Br
rolfo333
Oh Yes forgotten it in howto when i changed from 4760 to 8770, you are right the new name is Oracle
Maybe it is better I am only have done this and it was enough
ACFE OXE R11.1 | ACSE OpenTouch R2.0 | ACSE 8770 R2.5
ghost_gigi
Post by ghost_gigi »
doublezero wrote:1) Change directory: 8770\SunONE\slapd-8770\config
2) Edit: 'dse.ldif'
3) Modify line: nsslapd-rootpw: {SSHA}5lh……
New entry: nsslapd-rootpw: {CLEAR}hugo
(CLEAR means you can fill in the password in a readable format – like 'hugo')
DON'T SAVE THE MODIFICATON YET!
4) Stop service: 'Sun Directory Server 7.0 Control Center'
Stop service: 'Sun Directory Server Enterprise Edition 7.0'
5) SAVE the modification of 'dse.ldif'
6) Start service: 'Sun Directory Server 7.0 Control Center'
Start service: 'Sun Directory Server Enterprise Edition 7.0'
(The 'Sun Directory Server Enterprise Edition 7.0' should start automatically, if not start it)
7) Use the ToolsOmnivista.exe to change the password of the 'Directory Manager'; otherwise the password isn't encrypted in the 'dse.ldif' file.
many thanks doublezero, you saved me! :) :)
I managed to restore a backup that failed because of wrong password .... thanks to your procedure, I replaced the {SSHA} with {CLEAR} passwords used during backup, and now the procedure is successful!
Very very thanks! It caused me many pains!
Luigi
mejust
Post by mejust »
Than you it worked. 5 stars
Benjamin Metz
Post by Benjamin Metz »
Saved my life today, too.
Thank you so much!
vicentc
Post by vicentc »
hi please I have tried all the recommendations but I have not been able to reset the password for omnivist 8770. help
8crespo8
Post by 8crespo8 »
Could you please help me, I am following the steps to change the Directory Manager password but when I enter ToolsOmnivista.exe and try the new password it does not accept it, I return to the "dse.ldif" file and I see that it is not encrypted yet .
I restart the server and look at the file again and see that the password is already encrypted but when I enter ToolsOmnivista.exe it still does not accept the password.
Omnivista version 8770-32.2.08.10b
attached capture, thanks.
istration,cn=8770Applications,o=nmc");)
nsslapd-sizelimit: -1
modifiersname: cn=directory manager
modifytimestamp: 20190327145331Z
w==
8crespo8
Post by 8crespo8 »
Please can you help me with this issue.
Thank you
Return to “OmniVista 8770”
