OV 3.5.6 and OmniSwitch 6860
strelok
Post by strelok »
Hello !
We have just installed OmniSwitch 6860 and it's first 6860 in our network.
We use OV 2500 3.5.6 and I'm trying to setup monitoring but without success.
So, I suspect that this model is not supported by OV 3.5.6. Am I right ?
Re: OV 3.5.6 and OmniSwitch 6860
yes, you need 4.x.
With an update lic from old OV to the new 4.x you have also a lot of new features. The best is that you don't need java anymore.
Return to “OmniVista 2500 v3.5”
