run pbxstat d xxx in a script
Did you say hacking ?
sebwa2k
Post by sebwa2k »
i would like to automate a Status report of a hunting group on Alcatel oxe.
The Command
pbxstat d xxx |grep in > result.txt
writes the active numbers of this Group to result.txt
Now i want a cronjob to do this every 10 minutes.
*/10 * * * * pbxstat d xxx |grep in > result.txt
in mtcl.cron does not work, contab -e does not Show this cronjob.
Can anybody help me with this Problem?
Best Regards,
Sebastian
sadim
Re: run pbxstat d xxx in a script
Post by sadim »
The crontab entry should be:
*/10 * * * * /usr2/oneshot/mtcl/tool pbxstat d xxx |grep in > result.txt
Return to “System Hacking”
