Lost the mtcl password in R12.
Lost the password for mtcl account.pbx version is R12.0,in CPU7-2.somebody can help?
AQPS ACFE ACSE
Re: Lost the mtcl password in R12.
login to CPU console and try to give the su and password : xxxxxxxx and check the login is happening
no passwords are to be given on this site at all!!!
thx hussainqcs and oldboy.
I want to crack the mtcl password .edit the grub , and login the root to modify the mtcl passwd.
lost all the password : root swinst mtcl.
1.boot the oxe and press e in grub menu,modify the kernel line to a single mode.
2. press b key to continue boot .
3.but the prompt me to enter the root password. no the bash prompt .why
AQPS ACFE ACSE
- tot3nkopf
Search the forum (a doc was uploaded by Frank long time ago). You need a reboot and to access the grub.
Old the method cannot used.because the version R12 use the new OS is centos.
AQPS ACFE ACSE
- tot3nkopf
Then classic Linux way. Mount the HDD or partition on a different Linux, etc...
Do you have saved database?
I want to recover the root pwd. such as the forum document R9.1 root password recover.
AQPS ACFE ACSE
