oxo vpn no audio
archito
oxo vpn no audio
Post by archito »
Hi guys,
I have the following scenario:
I have a site-to-site vpn with fortigate.
Vpn was created to use the same data network (both sites use the same 192.0.0.0/24 network), fortinet facilitates this task by creating virtual ip mapping to the internal network.
I am wanting to pick up the phones in the place where the pbx is not, edit the vpn and add the route so that the phone using local network can lift thing that happened satisfactorily.
However I have a problem with the audio, I can not hear the voice in the internal call nor the vocal guides
If you have any suggestions, I thank you
Re: oxo vpn no audio
As many many times before, audio means RTP being blocked. Ask your VPN guys to check UDP traffic. Also search the forum for many many posts like yours
Return to “Networking”
