I have a below error when I open the application even in task manager the pid for that process not running
Has anybody has solution
I am using Windows 10 PC
Omnivista 3600 VRF not opening
Re: Omnivista 3600 VRF not opening
Find the vrfplan.lock file and delete it in mentioned folder !!! That's it. there you go !!!
I tried it still same issue
Delete all vrfplan.lock files in the same PC and give the application a restart. It should work !!! if not you may have to install the application again.
I tried all the steps what you suggesting now but still no success
