I was loading the release in VMware with Release 12 but I was unable to get the login prompt instead I’m getting
Grub loading stage 2...output on serial line
Is anybody having solution for that ?
Unable to get OXE login prompt
- cavagnaro
Re: Unable to get OXE login prompt
Please don't double post around.
Maybe you had an error at the installation and missed it.
Check it again
Check it again
what did you load the VM as ??? try Blade server from PC Installer, If i remember correctly if you choose app server you need to have a terminal service setup
Thanks old boy I tried with Blade server and it works fine
