Name not display
A H323 and SIP forum only !
mdhussainvlr
Re: Name not display
Post by mdhussainvlr »
3505 - Avaya SIP
3502 - OXE
when the call is made (toward the avaya)
Wed Sep 26 22:52:26 2018 116e[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
Wed Sep 26 22:52:26 2018 116e[CMotorCall::emitInviteMessage] From: "Abdullah" <sip:3502@192.168.30.254;user=phone>
response from avaya
Wed Sep 26 22:52:26 2018 [CPoceedingState::receiveInformationalMessage]-->nof of PEM hdrs 0
Wed Sep 26 22:52:26 2018 [receiveInformationalMessage] No P-Early-Media header received
when the call is retrieved from hold( as an incoming call from avaya)
Wed Sep 26 22:52:38 2018 116e[CMotorCall::emitSuccessfulMessage] P-Asserted-Identity: "Abdullah" <sip:3502@192.168.30.25
4;user=phone>
see PEM parameters fro incomingandoutgoing call in the sip gateway
According to OP he is not using a GW, he just plugged the Avaya sip phone to the OXE. So, for me, that is the behavior at the sip end point from Avaya.
internal sip config ?
enio.eltz
Post by enio.eltz »
Hi all
I am just curious about this.
mdhussainvlr, let me see if I understand your case. When you call from an extension of OXE to a SIP extension (Avaya set registered on OXE), Avaya set does not show the name of who is calling, right?
If I understood right, I ran a test with a lab system I have with one KS 4039 and one SEPLOS. Release is R11.0.1. For SEPLOS, I used a simple softphone. When the softphone rings, it shows name and number from who is calling.
Checking the traces out, I can see when OXE sends the INVITE to the softphone, it sends the name on the FROM field:
From: "ENIO ADM" <sip:55000000@172.21.0.11;user=phone>;tag=8cefef150b885cdd19fac236a2b4546f
OXE does not send P-Asserted in this case.
From your trace, I can see the INVITE is sent with the name on the FROM field:
From: "Abdullah" <sip:3502@192.168.30.254;user=phone>;tag=7a0a5e4a013dbfa2eca0e1decdcb0620
So, I understand there is nothing to do on OXE side. In my opinion you need to verify Avaya set configurations to see if it can read the name from the FROM field.
Other thing. Probably this is not a set certified by Alcatel. In this case there might be some funtions that will not work.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
mdhussainvlr
while in SIP trace oxe name was not showing in the To header field during ringing
mdhussainvlr
Please find the SIP trace for two call ImageImagescenarios
Scenario 1: OXE to Avaya
In Avaya no name showing only number
Scenario 2 : Avaya to OXE
In Avaya both name & number showing
sdp in 18x yes or no?!
CONTENT-length:0 !!
mdhussainvlr
Hi haroun,
Will that make issue resolved ?
Test! And let us know!
Return to “H323 / Sip”
