Problem solved!
I had to set "PAI" instead of "yes" in the xivo trunk configuration "send remote party ID" and now this is what i receive on oXE:
"P-Asserted-Identity: "Delphine D" <sip:728@xxxx>"
and "Delphine D" is well displayed on caller phone.
Display Name on trunk
Re: Display Name on trunk
HI RECHECK ur sip trace and i figure out that the file was some how cut , and on the cutten part i can see :
re is 0 P-Asserted-Identity header in the message.
Hello Haroun,
Sorry i dont understand what you ask.
Problem is solved from oxe to xivo but now i have the problem from xivo to oxe... it doesn't display the trunk name but only the called number with no name, i check trace on xivo and oxe doesn't seem to send PAI to xivo when there is an incoming call.
"P-Asserted-ID in Calling Number" is set to true on the ext gateway to xivo on OXE.
ty
ty
Ok now its fixed on both ways.
"P-Asserted-ID in Calling Number" had to be to false for this last problem.
ty
ty
creat the trunk group as ABC-F not QSIG and give it a try
I have almost the same problem with my sip declarer device behind my OXE R100,
caller names and call not showing from sip device to sip device
on the other hand is displayed towards the TDM digital stations
can you help me to define the cause.
Thanks in advance
Thanks in advance
try by creating the local sip tg as abcf and the for external sip gateway create a sip tg with isdn all countries. this resolve issues when i used trunks in qsig. never had issues with sip.
