Hi all.
I need to interface two ALE systems through two media gateways (and not through the CSs).
How could i define this system? Do I have to put BRA boards in each of every media gateway?
Will they communicate in QSIG? And what can/cannot they do with this connection (what kind of services)?
Thank you.
Interfacing media gateway
Re: Interfacing media gateway
What kind of ALE system do you want to connect ? OXE or OXO ?
For OXE system there is different scenario, do you want to share the configuration (COS, Numbering plan, entities, public trunk ....) between the two system or you just want to make call between the 2 systems ?
The system documentation has a big chapter about the network design and configuration.
Turlupin
Turlupin
Sorry for my english ....
Two OXE systems.
I need to propose a direct interconnection through peripheral MGW boards. They have to be able to call each other, (no shared public trunk and no shared configuration).
Thank you.
Thank you.
So you just need to create a private ABC-F2 trunk beetwen the 2 OXE. The trunk can be IP or TDM with BRA or PRA board.
