hang up call between a terminal and a trunk.
siatmex
Post by siatmex »
I need to stop a call generated from a terminal to a trunk, try to stop it with the command outserv n but the call still does not hang up, any idea.
Thank you.
Re: hang up call between a terminal and a trunk.
lot of ways
reset witch is not the adequat ,to do at each call
or discrimination
btw delete duplicated topics (u have 3 for the same case )
alex
Post by alex »
"outserv" is very polite command, :oops: it just waits for the all calls to end and only after that it takes an equipment out-of-service.
siatmex
Post by siatmex »
That is the question. I do not want the call to take place. I want to stop it when it is being carried out.
What happens is that in Mexico the prefixes were removed, so I can no longer block cell phone calls, make a script to identify what cell phone calls are and if it does, but I use to stop it and the outserv command does not .
Return to “External Services”
