Change Interface Type CS to CS3 OXE 12.3
Harry
Post by Harry »
We have start the maintenance over a OXE 12.3 with 500 users, which has the wrong callserver board type after upgrade from Rel 10.0 to 12.3. :?
Is it possible to change the board type from CS to CS3 on a running OXE 12.3 without any problems?
How is the correct way to change the board type?
Thx for helping us :)
(101)xa001001> config all
Tue Mar 17 23:14:58 CET 2020
Crystal 0 :
| 0 | 6 | CPU_CS3|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 10 | CPU_CS3|---------- |ONLY MAO FILE | BAD PCMS CODE |
> Reference rack not set
Crystal 1 :
| 1 | 0 | GD3|---------- | IN SERVICE | BAD PCMS CODE |
| 1 | 1 | UAI 16|---------- | IN SERVICE | BAD PCMS CODE |
| 1 | 2 | UAI 8|---------- | IN SERVICE | BAD PCMS CODE |
| 1 | 3 | UAI 16|---------- | IN SERVICE | BAD PCMS CODE |
| 1 | 4 | UAI 16|---------- | IN SERVICE | BAD PCMS CODE |
| 1 | 5 | UAI 8|---------- | IN SERVICE | BAD PCMS CODE |
| 1 | 6 | BRA 4|---------- | IN SERVICE | BAD PCMS CODE |
| 1 | 8 | CS|---------- | CALL SERVER | BAD PCMS CODE |
--- Inter Crystal Topology ---
| CR | CPL Type Role Free/Tot Role Type CPL | CR |
|001 | 00 -GD3 (INT_A ) === 78/78 === ( MAIN) pwMEX - 00 |002 |
|001 | 00 -GD3 (INT_A ) === 78/78 === ( MAIN) pwMEX - 00 |003 |
|001 | 00 -GD3 (MAIN ) --- 60/60 --- ( INT_A) INTIPA - 01 |019 |
Crystal 2 :
| 2 | 0 | pwMEX|---------- | IN SERVICE | NO PCMS CODE |
| 2 | 1 | UAI 16|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 2 | UAI 16|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 4 | UAI 16|---------- | IN SERVICE | NO PCMS CODE |
| 2 | 5 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 8 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
|002 | 00 -pwMEX (MAIN ) --- 78/78 --- ( INT_A) MGD3 - 00 |001 |
Crystal 3 :
| 3 | 0 | pwMEX|---------- | IN SERVICE | NO PCMS CODE |
| 3 | 1 | UAI 16|---------- | IN SERVICE | BAD PCMS CODE |
| 3 | 2 | UAI 16|---------- | IN SERVICE | BAD PCMS CODE |
| 3 | 4 | UAI 8|---------- |ONLY OPS FILE | BAD PCMS CODE |
| 3 | 5 | SLI 8 (Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 3 | 8 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
|003 | 00 -pwMEX (MAIN ) --- 78/78 --- ( INT_A) MGD3 - 00 |001 |
Crystal 4 :
| 4 | 0 | GD3|---------- | IN SERVICE | BAD PCMS CODE |
| 4 | 2 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 4 | 3 | MIX448|---------- |ONLY OPS FILE | BAD PCMS CODE |
| 4 | 4 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 4 | 5 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 4 | 6 | BRA 4|---------- | IN SERVICE | BAD PCMS CODE |
| 4 | 7 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
|004 | 00 -GD3 (INT_A ) === 78/78 === ( MAIN) pwMEX - 00 |005 |
|004 | 00 -GD3 (MAIN ) --- 30/30 --- ( INT_A) INTIPA - 01 |019 |
Crystal 5 :
| 5 | 0 | pwMEX|---------- | IN SERVICE | NO PCMS CODE |
| 5 | 1 | UAI 16|---------- | IN SERVICE | BAD PCMS CODE |
| 5 | 2 | SLI 8 (Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 5 | 4 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 5 | 5 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 5 | 8 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
|005 | 00 -pwMEX (MAIN ) --- 78/78 --- ( INT_A) MGD3 - 00 |004 |
Crystal 6 :
| 6 | 0 | UA_FICTIF| | IN SERVICE | NO PCMS CODE |
Crystal 18 :
| 18 | 0 | GD|---------- | IN SERVICE | BAD PCMS CODE |
| 18 | 1 | 4645|---------- | IN SERVICE | BAD PCMS CODE |
|018 | 00 -GD (MAIN ) --- 24/24 --- ( INT_A) INTIPA - 01 |019 |
Crystal 19 :
| 19 | 0 | FICTIF| | REG NOT INIT | NO PCMS CODE |
| 19 | 1 | INTIPA| | IN SERVICE | NO PCMS CODE |
| 19 | 2 | INTIPA| | OUT OF SERV | NO PCMS CODE |
| 19 | 3 | Z_FICTIF| | IN SERVICE | NO PCMS CODE |
|019 | 01 -INTIPA (INT_A ) === 60/60 === ( MAIN) GD3 - 00 |001 |
|019 | 01 -INTIPA (INT_A ) === 30/30 === ( MAIN) GD3 - 00 |004 |
|019 | 01 -INTIPA (INT_A ) === 24/24 === ( MAIN) GD - 00 |018 |
Re: Change Interface Type CS to CS3 OXE 12.3
Your config all shows that you have a CS3 setup.
Return to “Shelf”
