Factory rest
Re: Factory rest
normaly you need to open a ticket at ALE. But you will find the file in the attachment....
OS6465.zip
BR Silvio
mmankollari
Re: Factory rest
Post by mmankollari »
Hello again,
I'm sorry but I can't find the attached file.
Re: Factory rest
now it is available....
mmankollari
Re: Factory rest
Thank you!
Hendrik88
Re: Factory rest
Post by Hendrik88 »
silvio wrote: 12 Aug 2020 10:29 You need access to the business portal (for ALE partners only), or you ask the supplier of the switches (he should help you) or you can copy the file from an other OS6465 (via ftp, scp or USB).
BR Silvio
Hello Silvio
I want to upgrade the OS6465-P6 firmware . but I have no firmware for it. and I can`t download the firmware on business portal because i have no account for it. So, I will try to upgrade by copying files from another switches to USB drive . is it possible ? Could you please tell me how the steps to copy file ( nos.img etc,,) to USB drive ?.
Thank you.
Best regards,
Hendrik
Re: Factory rest
Return to “OmniSwitch 6465”
