Change power supply
neimad
Change power supply
Post by neimad »
I have changed a power supply from PS-I75AC to PS-I185AC-P on a 6465 switch.
I have to provision the switch with the correct wattage but I can't:
>powersupply 1 name Power1 type ALE hi-ac
WARNING: Power supply 1 is already configured, Remove existing configuration to add new Powersupply
I have some lanpower configuration. Should I stop lanpower service and then I will be able to change powersupply type?
lanpower slot 1/1 service stop
os6465-hdw-rev-e.pdf hardware configuration guide does not help in that case.
thanks for your help
Tommy124
Re: Change power supply
Post by Tommy124 »
You need to remove the provisioned power supply first with the no powersupply 1 name Power1 type ALE low-ac (just remove the old one), when you've done this you can provision the new power supply
Return to “OmniSwitch 6465”
