DECT synchronization issues
jadfaller
Post by jadfaller »
I'm new here and i need some information. I hope anyone can help me. Is it safe to change the PARI number on an IBS dect system and change it back to its original number? What will happen? Is this critical? Can this resolve IBS dect synchronization issue hypothetically?
We have 256 bs situated all around the area, and it shows 2 large group and some smaller groups (15 groups). some area are empty due to pandemic and not active. Every time I check the sync process (dectview syncibs) it always change to a lot of smaller groups and don't achieve full synchronization. Can anyone help to make all bs in 1 group? Any ideas?
Re: DECT synchronization issues
what OXE version are you running ?
jadfaller
Post by jadfaller »
8770
alex
Post by alex »
The main question is - do you have ACT or CH shelves?
Not what software. What version of OmniPCX Enterprise?
And Crystal or common hardware?
jadfaller
Post by jadfaller »
Alcatel-lucent omnipcx enterprise 4400. We use crystal topology.
All IBS BS connected to UA boards in the same ACT (or ACT connected via INTOF). Or exist BS with ACT connected via INTIP?
jadfaller, third time asking: software version please.
jadfaller
Post by jadfaller »
My apologies just got busy. Is this what you’re asking?
Alcatel-Lucent OmniPCX Enterprise
standard installation last performed: 02-Nov-2015 16:00:09
# The role of the CPU is MAIN
Application software identity
R11.1-l1.301-28-b-ge-c0
Business identification: R11.1
Release:
DELIVERY l1.301
Patch identification: 28
Dynamic patch identification: b
Country: ge
Cpu: c0
ACD VERSION
release : 11
bug_fixing : 2
protocol_id : 92
version_dy_hr_stat : 12
jadfaller
Post by jadfaller »
vad wrote: 03 Dec 2020 23:33 All IBS BS connected to UA boards in the same ACT (or ACT connected via INTOF). Or exist BS with ACT connected via INTIP?
Yes all ibs are connected to ua boards in different act connected by intof and sync by dect8 dtm
Return to “PWT/DECT System”
