I wanted to know if there is a way to export a subscriber to a file (maybe csv) in CLI with user mtcl like the export function in WBM or 8770 ?
In mgr, the export function doesn't exist.
The idea is to make a backup of some subscribers before their deletion, and maybe import them (in mgr -nodico -X ?).
Thank you.
Steven
Export Subscribers to a file in CLI like in WBM or 8770
- frank
Re: Export Subscribers to a file in CLI like in WBM or 8770
Just extensions, or full details ?
Just play with edsbr command. It's kind of interactive. Get help with "?".
To export all extensions do something like that (check all attributes with "? *")
The result is saved in /tmpd/edsbr.out file.
Just run following commads to create tab-separated file.
Just for one extension run. Check for spaces around the equals sign!
enter criteria or command:clear
enter criteria or command:dir
enter criteria or command:name
enter criteria or command:act
enter criteria or command:cpl
enter criteria or command:pos
enter criteria or command:typ
enter criteria or command:pna
enter criteria or command:fc
enter criteria or command:nblin FILE 1000
enter criteria or command:go FILE
grep -v "+" /tmpd/edsbr.out | tr "\|" "\t" > whatever_file.txt
enter criteria or command:dir = MCDU
