Hi ,
I have a 6850E switch (ver 6.4.3)
I want to configure authenticate 802.1x and MAC to the NPS Radius server for the workstation to it.
The workstation connects to port 1/7.
I attached the Configuration file
Please help me to check which part I configure wrong
I first time use Alcatel switch, not so familiar yet
DEV-SS1-FARM_SW1# show aaa-device all-users
Slot MAC User Addr IP Authentication User Network
Port Address Name Vlan Mode Address Type Result Profile Name
1/ 7 80:e8:2c:c9:20:1b -- 131 Blk - MAC Fail -
DEV-SS1-FARM_SW1# show 802.1x non-supplicant
Slot MAC MAC Authent Classification Vlan Dynamic
Port Address Status Policy Learned UNP
01/07 80:e8:2c:c9:20:1b Failed Basic-Blk 131 Disabled
DEV-SS1-FARM_SW1# show 802.1x device classification policies
Device classification policies on 802.1x port 1/7
Supplicant:
authentication:
pass: UNP Radius, default-VLAN
fail: block
Non-Supplicant:
authentication:
pass: UNP test, default-vlan
fail: block
Captive Portal:
authentication:
pass: default-vlan (default)
fail: block (default)
Authentication Vlan and MAC issue
Re: Authentication Vlan and MAC issue
Please help on my issue ASAP
Tips for getting help (especially since this is a forum of random volunteers):
1. If you're in a hurry you should get a consultant
2. You are more likely to get help if you show understanding of the issue
3. Don't just dump an entire config file, narrow it down to relevant bits, e.g. AAA and 802.1x sections:
! AAA :
aaa radius-server "SS1SECASM3" host 172.23.16.170 key f5dc1cc956c0ee9b5a6d0fb95a26bb76 retransmit 3 timeout 2 auth-port 1812 acct-port 1813
aaa authentication 802.1x SS1SECASM3
aaa authentication mac SS1SECASM3
aaa accounting 802.1x SS1SECASM3
aaa accounting mac SS1SECASM3
user password-size min 6
aaa user-network-profile name "Radius" vlan 131 hic disable
aaa user-network-profile name "test" vlan 131 hic disable
aaa classification-rule mac-address 80:e8:2c:c9:20:1b user-network-profile name test
! 802.1x :
802.1x 1/7 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/7 captive-portal session-limit 12 retry-count 3
802.1x 1/7 supp-polling retry 2
802.1x 1/7 supplicant policy authentication pass user-network-profile Radius default-vlan fail block
802.1x 1/7 non-supplicant policy authentication pass user-network-profile test default-vlan fail block
802.1x 1/7 captive-portal policy authentication pass default-vlan fail block
show configuration snapshot
show configuration snapshot aaa
AAA looks OK. You have "aaa radius server" and both accounting and authentication for both 802.1 and MAC addresses set up for that server. Why both though? Are you planning on using only 802.1x? Then you should remove the mac lines.
What do the logs say? From the RADIUS server and from the switch? You've put in that the default action if 802.1x fails it to block, and by golly it's not blocking for no reason.
Have you tried test credentials?
aaa test-radius-server
I'm only used to Cisco yet here I am :-)
