I have a problem that I can't solve, on the 6360-P24 switches, as on the 6250 24 ports, there are 25/26 rocades ports for SFP and 25/26 rocades ports for a copper link (Ethernet). Only I can't activate the Ethernet ports 25/26, when I put my ring link on it nothing happens, the port stays off. Is there a specific way to activate these 25/26 Ethernet ports?
Thanks in advance
Port 25/26 Ethernet 6360-P24
Re: Port 25/26 Ethernet 6360-P24
I can't find anything in the docu. But maybe it is the same like at the combo ports of the 6465T-models.
Try "interfaces 1/1/25-26 hybrid-mode copper"
best regards
best regards
Thank you for your answer. Indeed, that's right, I realized it just after I created the topic ... Thanks again!
Just adding a question i also have checking out the 6360-P24 we are testing SFP RJ45 transceivers and we are testing and ports 1/1/25-1/1/26 when we connect an SFP transceiver we get no active connection at all with other switches.
But when connect the same transceiver to the 1/1/28-29 it works without any configuration.
Tried your commands but did not work.I understand that since they are combo ports with RJ45+SFP the SFP perhaps is only used with fiber? Is there any way to verify that?
Thank in advace
Thank in advace
