QSIG Caller name is not showing on our 8039, 8029 and 8019 phone
ahqswitchroom4466
Post by ahqswitchroom4466 »
I Turn rn on calling name presentation under system -> other system param -> external system parameters. As well as i allowing Calling name display (CNIP/I-CNAM) in the phone features class of service
(1)ahqoxe2> t3
--> Cleaning mtracer...
| 0 | ** | ** | * | ** | * | *** | 165 |
| 1 | ** | ** | * | ** | * | *** | 166 |
| 2 | ** | ** | * | ** | * | *** | 167 |
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
Traces Analyser activated
mtracer started ...
(998213:000001:02868) MTRACER host (172.16.0.10, ahqoxe2), version: R12.4-m5.204-80-f-in-c0s1
(998213:000001:02868) MTRACER num: 003, time: 2022/02/17 21:16:27, loss: 0%
| (998476:000002:03464) Concatenated-Physical-Event :
| long: 89 desti: 0 source: 0 cryst: 6 cpl: 9 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 01 b1
| IE:[18] CHANNEL (l=3) a9 83 81 -> T2 : B channel 1 exclusive
| IE:[1c] FACILITY (l=43)
| [91] Discriminator of supplementary service applications
| [aa] NFE (l=6):
| [80] Source Entity (l=1) End_PTNX
| [82] Destination Entity (l=1) End_PTNX
| [8b] Interpretation APDU (l=1): DISCARD (0)
| [a1] INVOKE (l=29):
| Invoke Ident. : 0b6c (2924)
| OP: ECMA RO_CALLING_NAME (0)
| [30] Sequence (l=17)
| [80] Name presentation allowed (l=15) 'AHQ SWITCH ROOM'
| [80] Context specific (l=15)
| IE:[6c] CALLING_NUMBER (l=6) -> 09 80 Num : 4466
| IE:[70] CALLED_NUMBER (l=2) -> 80 Num : 4
| IE:[7d] HLC (l=2) 91 81
| (998476:000004:03429) 3429: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 26 desti: 0 source: 15 cryst: 6 cpl: 9 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : STATUS [7d] Call ref : 81 b1
| IE:[08] CAUSE (l=3) 80 e3 1c -> [e3]
| INFORMATION ELEMENT NON-EXISTENT OR NOT IMPLEMENTED
| IE:[14] CALL_STATE (l=1) 06
| (998476:000005:03429) 3429: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 6 cpl: 9 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP ACK [0d] Call ref : 81 b1
| IE:[18] CHANNEL (l=3) a1 83 81 -> T2 : B channel 1 preferred
| (998478:000006:03464) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 6 cpl: 9 us: 0 term: 0 type a5
| tei: 0 >>>> message received : INFORMATION [7b] Call ref : 01 b1
| (998481:000007:03464) Concatenated-Physical-Event :
| IE:[70] CALLED_NUMBER (l=2) -> 80 Num : 9
| (998483:000008:03464) Concatenated-Physical-Event :
| IE:[70] CALLED_NUMBER (l=2) -> 80 Num : 8
| (998483:000009:03429) 3429: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 18 desti: 0 source: 15 cryst: 6 cpl: 9 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 81 b1
| (998483:000010:03429) 3429: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 81 b1
| IE:[1e] PROGRESS_ID (l=2) 80 88
| [95] Locking shift. codeset : 5
| IE:[32] EI_PARTY_CATEGORY (l=1) -> EXTENSION (1)
| (998510:000011:03429) 3429: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 30 desti: 0 source: 15 cryst: 6 cpl: 9 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 81 b1
| IE:[4c] CONNECTED_NUMBER (l=6) -> 00 81 Num : 4498
| (998512:000012:03464) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 6 cpl: 9 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 01 b1
| (998535:000013:03429) 3429: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 81 b1
| IE:[08] CAUSE (l=3) 80 90 80 -> [90] NORMAL CALL CLEARING
| (998536:000014:03464) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 01 b1
| (998536:000015:03429) 3429: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 81 b1
Md Afzal Hossain
System Admin
alex
Re: QSIG Caller name is not showing on our 8039, 8029 and 8019 phone
Post by alex »
ahqswitchroom4466 wrote: 17 Feb 2022 10:39 I______________________________________________________________________________
Which QSIG you have configured - BC or GF?
OXE is ignoring IE FACILITY with Name Presentation.
ahqswitchroom4466
problem solved. thanks
Md Afzal Hossain
System Admin
and solution was ?
ahqswitchroom4466
If you configured E-1 as like qsig or isdn CLI not working. But your create your trunk as a ABCF trunk and select signal type Qsig. And this trunk group add on network routing table and ars route list. Finaly prefix creat
Prefix meaning: open routing no.
Network number: Ars route list no
Node number/ABCF trunk group: trunk group no
Md Afzal Hossain
System Admin
umer458
Post by umer458 »
having same problem, but alcatel oxe 4400 with huawei uSpace 1981 as slave exchange. Trunk group between them is QSIG trunk, now DOD and DID/ locall dialing all ok, showing number while huawei call alcatel, or vice versa but Name is not showing. Any suggestion to solve this?????
umer458
Post by umer458 »
and its done thanks
Return to “Trunk Groups”
