vlan tagging between multiple linkagg
slaskaridis
Post by slaskaridis »
I have created several linkagg to different access switches
i want to allow tagged Vlan for all created VLANS
in small series the commands I used were:
vlan 5 802.1q 1
vlan 6 802.1q 1
vlan 7 802.1q 1
what is the relevant command on 9900?
the only relevant i found is
: vlan 5-7 members linkagg 1-2 tagged
thank you
Re: vlan tagging between multiple linkagg
Yes, this is correct: vlan 5-7 members linkagg 1-2 tagged
But if the vlans are not in order you need to write this command for every single vlan or range of vlan.
slaskaridis
done, thanks!
Return to “OmniSwitch 9900”
