External Tickets arent generate by Pabx
m0jtaba
Post by m0jtaba »
hi
i use alcatel 4400, i have been setup the Accounting Application,now the accounting application showing Internal Calls , LocalLocalCall type ,
In
eaccclt -cpu Ip
the ticket about the External and Incoming from External call are not distinguish.
Mgr/Application / Accounting / is
 Internal Accounting + YES
                            Tracking + NO
                    Financial Report + NO
                 CDR Tickets Storage + NO
       Files for External Accounting + YES
            Real Time Tickets Output + Ethernet
and all filter has been add , is any Lock want to buy for external outgoing and external incoming calls ?or any setting ?
Re: External Tickets arent created by Pbx
Filter - 0 Units calls - added (I think you have no metering pulse from PSTN and accounting duration not managed)?
m0jtaba
Post by m0jtaba »
vad wrote: 06 Nov 2022 21:51 Filter - 0 Units calls - added (I think you have no metering pulse from PSTN and accounting duration not managed)?
hi thank you for respond .
im using the virtual trunk for PSTN.
m0jtaba
Re: External Tickets arent generate by Pabx
Post by m0jtaba »
Hi guys, is any where has config ? or just MGR/Application/Accounting ?
Return to “Application”
