Dear all experts,
Suddenly i cannot use password for FTP user to login my PABX.
I tried 3 FTP users but failed as below:
G:\>ftp 192.168.x.x
Connected to 192.168.x.x.
220 xa000000 FTP server () ready.
530 Please login with USER and PASS.
User (192.168.186.238:(none)): root
331 Password required for root.
Password:
530 Login incorrect.
Login failed.
ftp> exit
Invalid command.
ftp> quit
221 Goodbye.
G:\>ftp 192.168.x.x
User (192.168.186.238:(none)): swinst
331 Password required for swinst.
Password:
Login failed.
ftp> quit
421 Timeout (900 seconds): closing control connection.
G:\>ftp 192.168.x.x
User (192.168.186.238:(none)): mtcl
331 Password required for mtcl.
Password:
Login failed.
Although, i still can use user/pass: mtcl/mtcl to logon my PABX.
Below is my PABX version and user mtcl logon sucessful.
Welcome to xa000000
Alcatel-Lucent OmniPCX Enterprise
login: mtcl
Password:
Last login: Thu Jan 12 15:01:23 from 192.168.187.156
standard installation last performed: 09-Jul-2001 08:35:51
# The role of the CPU is MAIN
Application software identity
R12.1-m2.300-19-vn-c83
Business identification: R12.1
Release:
DELIVERY m2.300
Patch identification: 19
Dynamic patch identification: none
Country: vn
Cpu: c83
ACD VERSION
release : 11
bug_fixing : 3
protocol_id : 92
version_dy_hr_stat : 12
I donot know and never change password for ftp user.
I used the user/pass such as:
root :
swinst
mtcl :
So, my question is how i can retrieve password for ftp user?
Any help is appreciated.
Thank you so much.
Reset FTP user
Re: Reset FTP user
For ftp in PABX used user "adfexc"
And why you want establish ftp connection under root account?
Re: Reset FTP user
Hi Vad,
Before, i rem still use user/password: mtcl/mtcl to login ftp.
But now i cannot although did not change any more.
I tried user/password: adfexc/adfexc but not successful
Thanks,
Thanks,
Re: Reset FTP user
hi ftp user db corruption (not sure for your case) but see this topic how i solve it
https://www.alcatelunleashed.com/viewtopic.php?t=22812
Re: Reset FTP user
Hi Haroun,
My ftpaccess file like this one:
[root@xa000000 etc]# ls -al ftpaccess
-rw-r--r--. 1 root root 193 Nov 17 11:18 ftpaccess
and vi shown:
------------------Quote---------------------------------
# this file is used to configure module options
# for the bonding module. It is used by netadmin
# and mk_routes.
# do not edit it by hand
miimon=100
mode=1
passive ports 0.0.0.0/0 10000 10499
"ftpaccess" 7L, 193C
-----------------------------------unquote-----------------------------
But i am not sure how is going wrong and also do not have another site to compare...
Any help is appreciated,
thank you,
and vi shown:
# and mk_routes.
miimon=100
mode=1
thank you,
Re: Reset FTP user
that's clear your ftpacces is corrupetd
-rw-r--r--. 1 root root 193 Nov 17 11:18 ftpaccess instead of
.-rw-rw-r-- 1 root root 520 Mar 27 2022 ftpaccess
from a r7.1 oxe
vi ftpaccess
(5)LFr_cpu20> vi ftpaccess
class all real,guest,anonymous *
email root@localhost
loginfails 5
readme README* login
readme README* cwd=*
message /welcome.msg login
message .message cwd=*
compress yes all
tar yes all
chmod no guest,anonymous
delete no guest,anonymous
overwrite no guest,anonymous
rename no guest,anonymous
log transfers anonymous,real inbound,outbound
shutdown /etc/shutmsg
"ftpaccess" 25L, 520C
and from r9.1
vi ftpaccess
loginfails 5
compress yes all
tar yes all
"ftpaccess" [readonly] 25 lines, 520 characters
you should get some tools to get acces to oxe amd make file transfert or, make or revers ftp acces from your oxe to your pc or ftp server and download the good ftpacces
pm me if you want the file
from a r7.1 oxe
vi ftpaccess
loginfails 5
compress yes all
tar yes all
and from r9.1
vi ftpaccess
loginfails 5
compress yes all
tar yes all
Re: Reset FTP user
Hi Haroun,
Yes sure, i want to that file but i cannot find pm function to send message to you in this platform.
And wondering about how to access the OXE during ftp is error i did not know other tool. Please kindly advice me.
Last, a tons of thank you.
Best Regards,
Best Regards,
Re: Reset FTP user
make reverse ftp from oxe to any ftp server
