Mastercopy Failed
Mastercopy Failed
Hi~
When executing the mastercopy, as it reaches the end, the standby CPU will automatically stop and exit the process。
Sometimes it functions properly, while other times it does not function properly....
What could be the possible issue? oxe version is R12.2-M3402-26+Hot fix
Lee
Lee
Re: Mastercopy Failed
394.jpg is the fisrt time mastercopy failed , auto stop process
395.jpg is the second time mastercopy pending about 20min , I use Ctrl C to stop it
What items to check ? I've only looked at the log, nothing special
I've used checkdb before , but But I haven't input cdmao.
I'll try it , thanks
Your logs do not look like from swinst 2/3/1 menu.
Do you run mastercopy command from CLI? If yes, forget it. Always use swinst menu for CPU cloning.
Why Alex ??? it is the same thing
With swinst login - you have swinst rights and environment (my opinion).
