Mastercopy Failed
oldboy
Re: Mastercopy Failed
Post by oldboy »
vad wrote: 22 Aug 2023 22:54
oldboy wrote: 22 Aug 2023 19:17
alex wrote: 22 Aug 2023 07:06 Your logs do not look like from swinst 2/3/1 menu.
Do you run mastercopy command from CLI? If yes, forget it. Always use swinst menu for CPU cloning.
Why Alex ??? it is the same thing
With swinst login - you have swinst rights and environment (my opinion).
Yep just asking, never done it that way in the 25+ years of playing OXE but i know both will work, :D
alex
Post by alex »
Not actually.
"A long time ago in a galaxy far, far away...." there was a document from Alcatel about not using mastercopy from CLI, just use swinst menus. Can't find it now but this is written in R5.1 docs:
Lee0125
Post by Lee0125 »
Hi~~~
Today I did some tests
1. Main CPU -->no action
stand-by CPU--> use swinst (2-3-1) to run mastercopy is ok
2. Main CPU -->no action
stand-by CPU--> use mastercopy cmd to run mastercopy is ok
3. Main CPU -->user swinst to run immediate backup(2-4-1-1)
and choose 1、11
1 Backup mao, voice guides and accounting data
11 Backup Linux (Unix) site specific data
---When the backup execution is completed--
stand-by CPU--> use mastercopy cmd to run mastercopy is not ok
And then it will become as shown in the picture below, it reboot
4. Use swinst to run mastercopy again , similar to before, it will remain
stuck for about 10 minutes.
So, I proceeded to stop it again , it show message as shown in the picture
above
5. Next, I turned off the standby CPU and replaced IO2N.
After booting up, execute the master copy once again,then the system displays
-->Error mapping remagen, stat=-7
Duplication update for accounting has now started.
Accounting duplication update is already running.<--
Of course, it failed again...
Mention the third point , I'm accustomed to performing a backup of the main CPU
before executing the master copy . Because of the messages that appear in the end
,I'm guessing whether it's related to the backup item option1 (accounting data)...
ps : cdmao & checkdb , the result is as follows
(110)au8892a> cdmao
/DHS3data/mao
(110)au8892a> checkdb
Data base checking in progress ...
I would reinstall your OS from scratch :/
Lee0125
Post by Lee0125 »
I have previously replaced the hard drive~~
oldboy
Post by oldboy »
Have you done a database rebuild ?? fichges force_recover_dico make sure you do a cdmao first and then run that comand on the main and try and do a mastercopy
Lee0125
Post by Lee0125 »
A few years ago, when upgrading from R5.0Ux to R12.2, I followed the instructions in the system documentation and executed this command (upgrade steps R5.0Ux->R7.1->R9.1->R11.1-R12.2) , as shown in the picture
After that, I haven't performed a database rebuild
So you mean to run "fichges force_recover_dico" on the Main CPU first and then run the mastercopy?
During the execution process, it shouldn't affect phone usage, right? I remember it shouldn't...
oldboy
Post by oldboy »
Correct it wont affect a thing
Lee0125
Post by Lee0125 »
ok~ I'll try ,thank you !
Lee0125
Post by Lee0125 »
Hi~All
Today I did some tests again ( I have to perform routine checks every month )
1. replace IO2N with stand-by CPU -->Because the previous attempt to replace the IO2N didn't resolve the issue ,so it was rolled back
2. Use swinst to run mastercopy ( My plan is: If the execution fails, then I will run "fichges force_recover_dico" on the main CPU )
The process is as showed in the diagrams P1 to P3 . In the end, it's okay
According to the information from the diagram in P2, a similar issue occurred last time , but it seemed like had stop
, then I had Interrupted it .
The situation today is different .When it showed a message similar to the one in P2, the system automatically restarts.
Afterwards, it's completed . This process seems like it's completing the previously unfinished task.
I will continue to perform some tests on this issue, including this command "fichges force_recover_dico", if it fails next time."
There are any new developments, I will provide updates.
Thank you all for your suggestions.
Return to “MAIN”
