DM files generator
yiyo90
DM files generator
Post by yiyo90 »
Hi all!!
I have some 8082 phones, and I want to configure them to work with asterisk, but I don't have any software from Alcatel to generate the DM.
Can someone upload that firmware? or post all the files the phone needs and the path they ask?
Thanks a lot!!
Re: DM files generator
wouldn't it be easier to reboot the phone in SIP Mode directly ?
yiyo90
Post by yiyo90 »
Hi Frank,
I already tried that, however the phone doesn't allow you to configure any sip parameters via it's interface, what I have seen (from my searching, maybe there is another way to do it), is that it is mandatory to generate the DM files with the SIP configuration you want the phone to apply, put those files in a server, and then configure the phone to download those files.
BRs!
Try this doc
Return to “My IC Phone”
