802.1x with UNP and Wifi without Sellar
DenisElias
Post by DenisElias »
I need to configure 802.1x ports where APs will be connected. APs will be Aruba, auth infos will be coming from CPPM.
In the network guide I only see information for Stellar APs that are connected with SPB from the switch to the AP.
Is there a way to make a UNP where the untagged AP management vlan and a couple of tagged vlan are in there?
As of now the port config looks like this:
unp profile "xxx"
unp profile "n"
unp profile "xxx" map vlan 20
unp profile "n" map vlan n
unp port 1/1/1-n port-type bridge
unp port 1/1/1-n direction both classification trust-tag ap-mode dynamic-service none
unp port 1/1/1-n admin-state enable
unp port 1/1/1-n 802.1x-authentication
unp port 1/1/1-n mac-authentication
For wired ports everything works as intended and is tested but is not live yet.
Is there a way when a AP gets authorized to have one untagged and several tagged vlans assigned?
Re: 802.1x with UNP and Wifi without Sellar
You are looking for 802.1x of the wireless clients? Than you need the config at the AP or controller.
Or has the AP to authenticate via 802.1x at the switch? Than this is like a normal pc with certificate.
BR Silvio
Return to “OmniSwitch 6560”
