Hi, a few days ago the SSH service on the switch suddenly stopped working. I started the service in TELNET and I have remote access, but I can't fix the problem. Does anyone have an idea how to solve the problem.
shlomo itzhak
ssh to 6900 stop working
Re: ssh to 6900 stop working
you can check with "show ip service" - try to disable/enable it. You can check for open sessions (who) and kill unused. Check the source-ip of the ssh service, check tcp session (show tcp ....).
But if f you haven't changed anything there (f.e. ip interfaces or routes, use the same terminal tool without an update) you need an reboot (maybe with an update of the switch).
BR Silvio
BR Silvio
Hi, I did everything except the update version and it didn't help. There is one more idea before I upgrade.
open a ticket at ALE
Maybe there is a way. But the update (depending from your actual used release) helps often also for other points in your network. So I would prefere it.
- Gleylancer
Opening a ticket at ALE with an old firmware will always result in "update your firmware".
maybe... depending from your used release and from your paid support contract.
