Power Outage Card Out of Service
Gaoct
Post by Gaoct »
Hi ,
We encountered a consequent power cut and when the power came back our phone system did not restart .
I connected on the pbx using telnet and the comand config 3 to check my board status :
Do you know if i can use the command rstpcl 3 20 to restart my INTIP3B and restart our system ?
Thanks for your help !
Re: Power Outage Card Out of Service
I think this command not help you.
Wih power in shelf 3 - everything Ok?
Can you ping INTIP3B?
Gaoct
Post by Gaoct »
Power in shelf is OK , Network LED is on on INTIP3B but i don't know the IP.
Phones work when connected directly to the Alcatel equipment
Check alarm indication on INTIP3B board. Connect PC with RS232 to INTIPB and ckeck configuration and alarms.
Gaoct
Post by Gaoct »
I tried to connect via Putty on the serial but i am just having a black screen . I also tried to restart the card while the Serial cable is connected but nothing show up on the console
Gaoct
Post by Gaoct »
Hi ,
Quick update on the situation .
I managed to get text on the serial connection ( picture attached ) it was not working with a classic console cable and had to go rj11 > rj45 > serial for it to work .
THe INTIP3B card start correctly and the boot sequence finalise with the root login ( picture attached )
the configuration on the INTIP3B card was not wiped and it keep the ip address and all the relevant information's
But we are still having no phones/out of service card ( same as previous answer to this post )
I cna provide the full boot log but an specialist tried it and didn't see any issue .
His 2 options are :
- Hardware issue
- Switch issue/network issue
Gaoct
Post by Gaoct »
Forgot to add , i can ping everything from telnet/putty/OmniVista computer
DID u see the opposite intip (intipA) state?
Check incidents (CPU), may be you have incidents about PSAL alarm or reason about INTIPB not started. Show all INT-IPB start (log).
Gaoct
Post by Gaoct »
Thanks for the reply , attached the boot sequence
Return to “Shelf”
