Replace rack L for an rack M
aflores
Post by aflores »
Dear friends, hope every body is fine.
OXE CH rack L got damage, have no choice to get another one. Instead of rack L I have an rack M.
Has any of you used a rack M for OXE working properly?
I already connect the GD and it is working fine but I don´t have connect the CS yet since I am afraid it can get damage.
Any consideration about to do this, will be apreciated.
Thanks for yours consideration.
Regards.
AFLORES
Re: Replace rack L for an rack M
There is no Rack M.
Only Rack Small, or Rack Large.
aflores
Post by aflores »
Thanks Frank
I think rack M will works. GD in position 0, CS in last slot.
Return to “Shelf”
