QinQ question
dolan23
QinQ question
Post by dolan23 »
Hi everyone.
I am trying to make a network topology as follows
The idea is to try to get the ip's of vlan 2 and 4 to the other end through an epipe or vpls using qinq on the ports of the Nokia router that connects to the sw_cisco.
I have the following configurations
switch
interface Ethernet0/0
 description to_nokia_A
 switchport trunk encapsulation dot1q
 switchport trunk allowed vlan 2,4
 switchport mode trunk
 duplex auto
interface Ethernet0/1
 description pc1_vlan2
 switchport access vlan 2
 switchport mode access
 duplex auto
Router
A:Nokia_A# configure port 1/1/4
A:Nokia_A>config>port# info
        ethernet
            mode access
            encap-type qinq
        exit
        no shutdown
A:Nokia_A# show service sdp
Services: Service Destination Points
SdpId  AdmMTU  OprMTU  Far End          Adm  Opr         Del     LSP   Sig
109    0       8682    10.100.10.5      Up   Up          MPLS    R     TLDP
Number of SDPs : 1
Legend: R = RSVP, L = LDP, B = BGP, M = MPLS-TP, n/a = Not Applicable
        I = SR-ISIS, O = SR-OSPF, T = SR-TE, F = FPE
A:Nokia_A#
A:Nokia_A# show service service-using
Services
ServiceId    Type      Adm  Opr  CustomerId Service Name
10           Epipe     Up   Up   1
2147483648   IES       Up   Down 1          _tmnx_InternalIesService
2147483649   intVpls   Up   Down 1          _tmnx_InternalVplsService
Matching Services : 3
A:Nokia_A#
*A:Nokia_A>config>service>epipe# info
            sap 1/1/4:2.* create
                no shutdown
            exit
            spoke-sdp 109:10 create
                no shutdown
            exit
            no shutdown
I have tried to change the sap as 1/1/4:10.* but it doesn't work. I can only ping one vlan at a time (with the configuration above).
My question is, is what I am trying to do achievable or is there something missing to make it work?
Any ideas are welcome, thanks
aviviis
Re: QinQ question
Post by aviviis »
Try to change the sap to *.*
dolan23
Re: QinQ question
Post by dolan23 »
Hello, thank you for the reply.
I tried but it is not possible.
*A:Nokia_A>config>service>epipe# sap 1/1/4:*.* create
MINOR: SVCMGR #1611 Invalid encapsulation value for the port's encapsulation type - SAP *.* is not supported
gkigen
Re: QinQ question
Post by gkigen »
have you considered using null encapsulated sap on epipe. then define vlans on the switches sap end
Stoffen
Re: QinQ question
Post by Stoffen »
If you want only one e-pipe, you have to change the encapsulation on Nokia devices from QinQ to Null, and use sap 1/1/4.
If you can live with one epipe per VLAN, just create:
epipe 2
sap 1/1/4:2.*
epipe 4
sap 1/1/4:4.*
Or change ports on Nokia towards switches to dot1q, and skip the .* in the sap's.
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
Return to “7750 SR”
