OXE R100.1 SIP trunk 403 after kill sipmotor
morio
Post by morio »
hi all,
once again another issue with sip trunk, something strange. if a kill the sipmotor i can not make any incoming calls. oxe reply with 403. but i can make a out going call. and once the out going call is done, i recieve incoming calls. that also if the sip trunk is not busy for about 2 hours again i dont have incoming calls until i make one out going call. traces will be attached, please assist me onthis pls..
thanks in advance
morio
Re: OXE R100.1 SIP trunk 403 after kill sipmotor
Post by morio »
please finf the traces herewith,,,
Looks like SW error.
Or you have problem with NAT table on router.
morio
Post by morio »
thanks for the reply, yes i am planing to patch upgrade it, since the running patch is quite old. it could be a BUG as usual. i will keep it posted.
thanks again
Return to “SIP”
