Virtual-Chassis of OS6900-X40 & OS6900-X48
successor169
Post by successor169 »
We have a virtual-chassis setup comprising two OS6900-X40 switches, and the customer is considering adding two more OS6900-X48 switches. We need confirmation that the new OmniSwitches will be compatible with the existing ones.
Gleylancer
Re: Virtual-Chassis of OS6900-X40 & OS6900-X48
Post by Gleylancer »
The old and new version of the 6900 have different software images, which should make them incompatible, perhaps Silvio knows more.
While I cannot confirm their compatibility, either way it is not a good idea to even try. The X40 is end of life and will stop receiving Software Updates. Consider replacing them. If you are in a consulting role, it should be your recommendation.
correct. The old hardware (X20/40, T20/40, X72/Q32) can be connected in one VC up to 6. And all new switches too (X24/48, T24/48, V72, C32). But the old switches and the new one can not connected together in one VC.
BR Silvio
successor169
thanks for the confirmations
Return to “OmniSwitch 6900”
